Any good options other than Chief MWHVB for constant movement of TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 07-29-2013, 01:24 PM - Thread Starter
airscapes's Avatar
Quoted: 356 Post(s)
Liked: 287
After looking at Monprice and Chief, it looks like the chief MWHVB is what I need. http://www.chiefmfg.com/Products/MWHVB
Anyone know of a similar mount (single arm 25" extension) that is less expensive and as well made? This will be moved every night from closed against the left wall to fully extended and turned. (see attached). TV is a 46" LED 30lbs.. Chief is $260. Placement will be on that left wall so it will be about where it is in the picture but a little bit higher. It is only used during the day or when I am not watching TV ;-) No little box for me..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #2 of 2 Old 08-01-2013, 06:25 AM - Thread Starter
airscapes's Avatar
Quoted: 356 Post(s)
Liked: 287
Bump.. I change the title to be move descriptive of the advice I need.
Doug
