Help With 5.1 Room Layout … Rear Surround Speaker Placement - Pics! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 07-31-2013, 08:44 PM - Thread Starter
AdamITR's Avatar
First the equipment I'll be using … currently a 3.1 setup:
Sound Processor:
Lexicon DC-1
Power Amps:
Amp 1: AudioSource Amp 100 (Bridged - Center Channel)
Amp 2: Audioengine N22 (Powering L/R - Speakers) … will replace this soon with a new amp
Amp 3: TBD
Speakers - A mix & match:
L/R Mains: Klipsch Heresy 1's (Like these for 2ch listening too)
Center: Vienna Acoustics Theatro
Subwoofer: Klipsch SW-110
Rear Surround: TBD
Ignore the BA speakers mounted on the wall.
Visual:
Panasonic 42" Plasma
Samsung Blu-Ray Player
Mac Mini/Apple TV
I currently use the room as a home office too, so I have a desk/computer in the room. The room size is 14' x 13'. There is a large closet on the back wall … on the opposite side, 2 large windows. On the right wall, another window. And then the door entrance (see pic).
I have a single recliner chair currently positioned in the center of the room facing the TV and equipment.
Does anyone have suggestions where I could put the rear surround speakers? I don't want to use stands as I have a dog, 2yr old, and there is not a lot of room. With the other furniture in the room (Fly Fishing Desk, etc), even wall mounting is hard to do.
Any ideas? Rear Speaker recommendations would be helpful too.
Pics:
AdamITR is offline
post #2 of 8 Old 07-31-2013, 09:10 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
In-ceiling would be viable - do you have access above?
jautor is online now
post #3 of 8 Old 07-31-2013, 09:18 PM - Thread Starter
AdamITR's Avatar
Good idea, but I have no access above ... I could mount the speakers on the ceiling ... but wiring could get messy??
AdamITR is offline
post #4 of 8 Old 08-01-2013, 12:07 AM
jautor's Avatar
Liked: 777
Then on the wall flanking the closet doors is about your only choice. You can use the crown molding to run the cable around the room and up/down the wall cavities to get there. They won't be symmetric to your seating position, so some adjustments in the processor will be in order.
And you should look at least at an Emotiva amp for all of those channels...
post #5 of 8 Old 08-01-2013, 08:56 AM - Thread Starter
AdamITR's Avatar
I can do that! I can even use my Boston Acoustic speakers .... save some money. Any tips on how to secure the wires to the molding and walls??
AdamITR is offline
post #6 of 8 Old 08-01-2013, 10:37 AM
jautor's Avatar
Liked: 777
I'd run the wires in the wall, pull the molding off in places to run the wires behind it. If you want simple the cable raceway products like wiremold, or just tack the cable against the molding and paint it the same color as the molding or the wall.
post #7 of 8 Old 08-01-2013, 11:54 AM - Thread Starter
AdamITR's Avatar
I need to do it the simple way ... thanks for the tip!
AdamITR is offline
post #8 of 8 Old 08-02-2013, 10:45 AM - Thread Starter
AdamITR's Avatar
Done!
AdamITR is offline
Klipsch Sw 110 Reference Series 10 Inch 200 Watt Powered Subwoofer
