Banana Plugs and Lossy Signals - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-31-2013, 11:04 PM - Thread Starter
MamaKrayma's Avatar
I just installed my first banana plugs on all my speakers and receiver inputs (except for the center input which I had to use a pin plug as it's a spring clip). These are high-quality Monoprice plugs and pins and I have a couple questions concerning banana connections in general:
If I screw the plugs down poorly, will I notice a loss in sound quality? For example, if the wire was too far down over the screw indents, would it chop off the wire when I screwed it down and lose signal?
Would stripping off an extra centimeter of wire covering expose more wire for signal loss as well?
Or is it a 0.0001% loss that a human ear can't detect?
MamaKrayma is offline
post #2 of 7 Old 08-01-2013, 12:02 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Probably more like 0.0002%...
Just make sure you get a good connection with all of the conductor, the rest is just to keep the cable from coming loose... The insulation is not shielding and will not affect the signal at all.
MamaKrayma likes this.
jautor is online now
post #3 of 7 Old 08-01-2013, 09:26 AM - Thread Starter
MamaKrayma's Avatar
When I screw the top of the plug on after the wires are fanned out, it inevitably forces an equal and solid connection with the copper, correct?
post #4 of 7 Old 08-01-2013, 10:34 AM
jautor's Avatar
Liked: 777
Yep!
post #5 of 7 Old 08-01-2013, 10:36 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
Technically, NO. However you are overthinking all of this.
If you fan out, the tightest connection will be with the strand that has the greates diameter, accounting for the flatness issues with the connector itself. In reality, I would recommend twisting the strands instead and clamping because the connection would then be spread evenly over all strands and the strands will spread out under pressure.
Basically I agree with Jautor (yet again). Get a solid connection and stop worrying.
jayn_j is offline
post #6 of 7 Old 08-01-2013, 11:45 AM
jautor's Avatar
Liked: 777
Yeah, I assumed he was talking about the type of connector where you DO fan out for the screw to catch it (the hidden wire-style).
But if this is a through-hole style banana plug, then do just as jayn_j said and twist the copper then tighten the screw. Basically, follow the directions for your type of plug and you'll be fine.
post #7 of 7 Old 08-01-2013, 10:28 PM - Thread Starter
MamaKrayma's Avatar
Yeah, I have closed screw-type (rear entry only) and I did the fan out method. Thanks to you both for your help. Now I just need to find myself a good dedicated CD player...
