help please to ensure TV does not slide off the rails of cheetah flat tv mount - AVS Forum | Home Theater Discussions And Reviews
Old 08-10-2013, 10:22 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
I have the following mount on the drywall
APDAM2B
http://www.amazon.com/Cheetah-Articulating-Bracket-Displays-Ethernet/dp/B000WL6YY8/ref=cm_cr_pr_pb_t
The 65 inch plasma TV barely fits on the mount rails. I am afraid it is going to slip off.
There are bottom screws but not sure how adequate to prevent slide off.
Anybody have any suggestions to arrest any sliding.
jk_bama is offline
Old 10-07-2013, 06:52 AM - Thread Starter
jk_bama's Avatar
Quoted: 21 Post(s)
No one has this problem?
jk_bama is offline
Old 10-09-2013, 04:54 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
May I suggest temporarily removing the TV from bracket attached to the wall and performing the following small modification to your TV mount.. All you need is a drill, drill bit and a two 1" long #6 machine screws, 6 or more small washers and 2 matching nuts. Basically you create a stop at the end of the mounting rail, or up against the inside part of the tilting bracket attached to the TV.
underachiever extraordinaire
weaselfest is offline
Old 10-15-2013, 10:01 AM
JBWIII's Avatar
Liked: 43
The side flanges on the mounting rectangle don't prevent the vertical brackets from sliding off the rails? From the photo on Amazon I don't see how it could slide off.
JBWIII is offline
