Need help with speaker placement in townhouse. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 08-19-2013, 08:57 AM - Thread Starter
rgieg's Avatar
Hi we'er about to move in to a townhouse and i was wondering what would be a good setup for my 5.1 book shelf speakers in the layout attached. i am going to be mountaing the tv on the wall near the stairs. any help would be greatly appreciated. Thank you.
home theather.JPG 40k .JPG file
Name:	home theather.JPG
rgieg is offline
post #2 of 9 Old 08-20-2013, 10:12 AM
sdurani's Avatar
Quoted: 5146 Post(s)
Liked: 3625
If the couch is going on the east wall, opposite the stairs, then I would put the surrounds high up in the back corners of the room, pointed towards the couch. The multiple reflective surfaces in the corner will help with envelopment; the wide spread will maintain stereo separation in the surround field.
Sanjay
sdurani is online now
post #3 of 9 Old 03-02-2014, 12:22 PM - Thread Starter
rgieg's Avatar
Hi I know its been a long time but im finally now ready to put them up. Are u suggesting the wall by the window and opposite it the wall by the opening to the kitchen? Thanks!
rgieg is offline
post #4 of 9 Old 03-02-2014, 12:22 PM - Thread Starter
rgieg's Avatar
Any other suggestions please?
rgieg is offline
post #5 of 9 Old 03-02-2014, 01:21 PM
sdurani's Avatar
Liked: 3625
Yes, I would mount the surrounds on those two walls, as far back as possible (i.e., in the back corners of the room).
Sanjay
post #6 of 9 Old 03-02-2014, 01:41 PM - Thread Starter
rgieg's Avatar
Would it work even if the side by the kitchen is further to the couch than the other side? Also would it be ok to hang it up high up by the ceiling? Maybe 8 ft up so it wouldnt look too weird? Id have it up and point it downwards towards the couch? Thanks alot for the input
rgieg is offline
post #7 of 9 Old 03-02-2014, 01:42 PM - Thread Starter
rgieg's Avatar
So the speakera would be facing each other
rgieg is offline
post #8 of 9 Old 03-02-2014, 04:41 PM
sdurani's Avatar
Liked: 3625
High up in the back tri-corners (where the back corners meet the ceiling) will sound fine. The speakers would be facing each other but, if you tilt them down, they'll be facing the listeners (better). While symmetrical placement would be optimal, being at different distances from the surrounds won't be a problem (your receiver will adjust levels & delays to make your surrounds appear the same distance away).
Sanjay
post #9 of 9 Old 03-03-2014, 04:38 AM - Thread Starter
rgieg's Avatar
Thank you very much sir
rgieg is offline
