Starting to plan a new HT. What should I get? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 08-20-2013, 04:04 PM - Thread Starter
benst's Avatar
Hi all,
I'm looking for advice on how best to set up a new home cinema, including seating and HT gear. We may have to do this in stages, and we need to do the wiring at the time the house is built, so if a projector is the cheaper/better option, we'll need a conduit put in the ceiling (it's double storey) by the builder, plus conduit and power/speaker wiring in the walls. In fact, we probably won't be able to afford to put the cinema equipment in for 6-12 months but we want to make sure we get the room set up correctly at the very least.
We've pretty much settled on a house design which can be seen here http://www.porterdavis.com.au/homes/lifestyle/marbella. It may be possible to get the room made bigger but not much.
The room
It's 4m x 5.2m which isn't huge and obviously limits our options.
Seating
Given the size, I suspect we'd have to put the screen on the wall at the bottom of the picture above, which would give us room (just) for a 4 seater cinema sofa such as the following which is 3.6m wide.
https://www.adriatic.com.au/products/4-seater-with-4-electric-recliners.htm
Does that look decent? We may have to settle for a regular sofa to save some money.
Would you actually put the sofa on the left wall or should we try to have two rows of seating?
The HT Equipment
We don't want top end gear, and we don't even know if we should go with a projector or just a 60+ inch TV.
Our budget is probably no more than $10k for the electronics and any room treatment to improve the acoustics.
The questions
  1. Which TV?
  2. Alternatively, which screen and projector?
  3. Which Bluray player?
  4. Which speakers?
  5. Which home theatre receiver?
  6. What else will I need?
Thanks for any advice that you can give.
benst is offline
post #2 of 4 Old 08-20-2013, 04:53 PM
jautor's Avatar
Quoted: 1218 Post(s)
Liked: 780
You should really consider a door for that room - I'm surprised that a builder would label and market a room as a home theater (as opposed to a general purpose 'bonus' or game(s) room) and not have a door. Sound will escape from that room and with the open floorplan, invade all other living areas in the house. Same for sounds from the game(s)room upstairs, you'll hear all that in the theater. All that assumes there's others in the house that are not all together in the theater room 100% of the time...
Which will also bring up HVAC issues - more than a few people in a room (especially once you add a door) and it will start to get warm, make sure they have some plan for that extra heat.
Worry about the room layout, and the wiring now. Equipment will come later - and will likely be replaced with newer models before you need to purchase any of it.
Two rows of seating will be problematic if you want to use recliners for all of them (you want 4 seats total, correct?). You'd really like to have the seating away from the walls for the best acoustics / surround sound - given the space arrangement that may not be practical, though.
A couple of theater recliners with a bar and stools behind it would work - if that would meet your needs...
Jeff
jautor is offline
post #3 of 4 Old 08-20-2013, 05:54 PM - Thread Starter
benst's Avatar
Thanks jautor!
I was thinking maybe a raised platform at the back, and two rows of three seats (perhaps non-reclining) in the back row. But front row may be too close to the screen.
Maybe 5.1 wouldn't be suitable for two rows of seats.
benst is offline
post #4 of 4 Old 08-20-2013, 07:23 PM
jautor's Avatar
Liked: 780
If you don't put a door on that room, you'll want the screen at the far end, like the arrangement in the floorplan. And even if you do add a door, entering from the rear of the theater is "better" anyway. Just lay out the door swing so that if you put in a platform, it doesn't interfere.
A platform with "theater seats" might work for a second row. A front "primary" row with recliners at 3-3.5m, with a row of theater seats ~1m behind, would get the main seats into a good position for both audio and video.
5.1 is certainly suitable for the room - so is 7.1 for any dedicated theater since you have placement locations for all the speakers. The concern is about the quality of the surround experience. Being too close to the rear/side speakers is not ideal - but not a reason to skip surround sound... If your arrangement is going to put the seats against the rear wall, in-ceiling surround speakers may be something to consider.
Jeff
jautor is offline
