Which direction to point? Townhouse HT Question... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 08-22-2013, 10:48 AM - Thread Starter
bhrm's Avatar
Building a home theatre in my new town home. There will be neighbours on both sides and I was wondering which way should I be pointing my fronts? Towards the "unfinished low headroom" or place fronts on that wall?
Goal is to minimize possible complaints!
Also any thoughts on sub placement in a room like that? I will be placing my 5.1 set up dead centre of that room.
bhrm is offline
post #2 of 5 Old 09-04-2013, 06:05 PM - Thread Starter
bhrm's Avatar
bump
anyone? anyone?
bueller?
bhrm is offline
post #3 of 5 Old 09-04-2013, 09:58 PM
LINDW4LL's Avatar
Is it just drywall between you and the neighbors? Or is there brick or something? I'm not too familiar with townhomes.
LINDW4LL is online now
post #4 of 5 Old 09-04-2013, 10:03 PM - Thread Starter
bhrm's Avatar
Drywall and insulation. No brick.
bhrm is offline
post #5 of 5 Old 09-13-2013, 01:00 PM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 436
Placement of equipment is not really a factor, but it's the levels you listen to will ultimately determine what your neighbors hear.
Best to do a sound test from inside your neighbor's condos. Only then will you know how the sound translates from your condo, and you can get direct feedback from your neighbors on what's acceptable.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
