My first build 'low budget' - completed - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 09-06-2013, 02:09 PM - Thread Starter
vivithemage's Avatar
Quoted: 23 Post(s)
You guys helped me a bit when building this out, thought i'd show ya'll the finished project ... I finished this a few months ago, so it's well broken in now.
Technical stuff + costs:
couches about $1600 from local furniture store
SUB:
1x Klipsch Reference RW-12d
FRONTS:
2x Polk Audio New Monitor 65T
REARS:
2x Polk Audio New Monitor 35B
CENTER:
1x Polk Audio New Monitor 15C
$790 for the audio equipment
MISC cables (sub cable, tweeter cables, shrouds/covers - $50 or so
Onkyo TX-NR509 5.1
$154
PROJECTOR:
BenQ w710st
$599
$1593 for all of the hardware, speakers, projector, and $3193 if you factor in the couche(s).
I love the sub, kicks real hard and deep. The audio is just great, love every minute of it. I am used to my 1BR condo where I could only have TV speakers. Another thing I love is being able to watch everything on a 8 foot wide projected screen. It is huge coming from my 60" plasma, and I thought that was huge.
Surprisingly I do not have a screen, the yellow wall actually looks great when throwing the image. The ONLY thing i'd like to do is drill a hole and route those projector cables a little better, but for now they work a-ok.
Here's some pics!
vivithemage is offline
post #2 of 5 Old 09-10-2013, 08:25 PM - Thread Starter
Quoted: 23 Post(s)
no comments, I am sad! haha
post #3 of 5 Old 09-11-2013, 10:10 AM
NickTheGreat's Avatar
Quoted: 386 Post(s)
Liked: 259
I like it. And the important thing is that YOU do.
I'd probably tidy up the wiring a bit, but nothing wrong with having a cheap system like that. And you always could update it later, as you go along. Better speakers, screen, etc. smile.gif
NickTheGreat is offline
post #4 of 5 Old 09-11-2013, 02:33 PM
neverfinished94's Avatar
Quoted: 44 Post(s)
Liked: 26
nice job considering the budget. I have a budget theater as well.
http://www.avsforum.com/t/1479528/neverfinisheds-neverfinished-theater#post_23724640
Check out my just over $5K theater build thread
neverfinished's neverfinished theater
neverfinished94 is offline
post #5 of 5 Old 09-11-2013, 03:42 PM
billybobg's Avatar
Quoted: 38 Post(s)
Liked: 45
I recommend that you look at the DIY Screen Section. You can make an excellent screen for about $300. It will make a difference. When I first turned on my projector I had dark brown walls and thought the pic was decent, but a screen will greatly improve your viewing.
Home Theater Man Cave: Onkyo 7.1 Klipsch LaScala Mains, Shortened LaScala Klone Center, Klipsch Academy Surrounds and Rears; Panasonic AE8000, Panasonic BDP 460, 117" DIY Screen.
Garage Man Cave: LaScala Industrial Splits; Second hand Denon Amp
billybobg is offline
