Ressessed box and HDMI keystones in 2x4 wall. - AVS Forum | Home Theater Discussions And Reviews
Old 09-15-2013, 06:29 PM - Thread Starter
telc's Avatar
When using a recessed box like this with HDMI keystones will there be room to plug the cable in, since the box it recessed plus the 1" the keystone will take up, i'm not sure if there will be room to plug the HDMI cable in. The wall cavity is 2x4 construction so only 3.5" of depth.
Edit:
I found the specs for the box: http://www.aimedia.co/media/line-drawings/TVBU505.pdf
I don't think there is room to use a standard keystone, I calculated it and there will only be about 1.2" from the back of the keystone sheetrock on the other side.
telc is offline
Old 09-15-2013, 06:42 PM
Colm's Avatar
Liked: 94
Depends on the minimum bend radius of the cable. You can always use a port saver to avoid damaging the cable by bending it too tightly.
Colm is offline
Old 09-15-2013, 07:06 PM - Thread Starter
telc's Avatar
One of these may work, just he CL2 cable in the wall is a bit heavy afraid it may come unplugged from gravity over time since the connector will be pointing down.
[img]
telc is offline
Old 09-15-2013, 07:25 PM
Colm's Avatar
Liked: 94
Originally Posted by telc View Post
...afraid it may come unplugged from gravity over time since the connector will be pointing down.
Tape the connectors together.
Colm is offline
Old 09-15-2013, 07:45 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 780
Assuming this is going behind a TV, you'd be better off using a scoop plate (or nothing) and bringing the HDMI cable directly out of the wall to the TV input. Reduces the number of connections, and also gives you a lot more angle / slack to connect to the TV (which may be parallel to the wall anyway). If the cable in the wall isn't long enough, a coupler would work (same as the keystone).
jautor is offline
Old 09-16-2013, 07:36 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
I like this brushed pass-through, been wanting to try it.
Arlington's Decora Feedthrough.
Just some alternatives to scoop.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
