Modify the arm length from wall to double. Is it Okay? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 09-16-2013, 04:40 AM - Thread Starter
hayder78's Avatar
Hi there,
I am intended to buy a tv mount which its arm can be extended by buying another unit and using the arm pieces to be added to the 1st unit:
http://multibrackets.com/3268.shtml
The nice thing with this model that the arm pieces are modular. I mean you can remove the 2 arm pieces or put one or put two or even more. However the company does not guarantee that it will holds the TV if I put 3 or more arm pieces.
The maximum weight that can be hold with this unit is 25 kg if there is 2 arm pieces (~40 cm arm length from the wall).
My question: If my Tv is 40 inch LED and weights just 10 Kg. Can I extend the length of the arm twice? Since the recommended weight is up to 25 Kg with 40 cm, does that mean with 80 cm arm length I can go up to 12.5 Kg (half the max. weight) without any problem?
I do not know where to ask and it is not easy to get an expert answer. Appreciate any help!
Many thanks
hayder78 is offline
post #2 of 2 Old 09-16-2013, 05:34 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
The manufacture is the only one that can answer that question.
http://multibrackets.com/c.shtml
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
