Height speakers format! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 09-21-2013, 09:48 PM - Thread Starter
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Hello people!
I'm having a dilemma... I want to go on the height speakers route. In my receiver's advanced mcacc, the height speakers depicted looks like center channels... Even if I see theaters everywhere with bookshelves at that position. WHich one is right?!?
Right now there is a center channel model that I'd like for heights on sale... But I could also get energy mini-rcs bookshelves...
So.. Is having two small center speakers for center speaker a bad idea? Or should I pick bigger bookshelves ? Can't decide haha!
Thanks in advance!
Polk Audio LSIM703, Polk Audio LSIM704c, Polk Audio RTI-A1 surrounds
Dual Reaction-Audio BPS212 turbo subwoofers
Marantz AV8801 preamp, Rotel RMB-1095 power amp
Pioneer Elite n50 network player
Marantz CD6004 cd player, Marantz UD5007 Blu ray player, Modded Rega RP1 turntable
Panasonic Tcl55dt60 led tv,Playstation 3 and a lot of old consoles
Aarghon is offline
post #2 of 6 Old 09-22-2013, 08:04 AM
Selden Ball's Avatar
Quoted: 3050 Post(s)
Liked: 1494
I'm not sure what distinction you're using between "center" and "bookshelf" speakers -- horizontal vs vertical speaker orientation, perhaps? At any rate, you just need good speakers which are compatible with your receiver, and which can be oriented so their tweeters point toward the primary listening position. Some speaker designs do have broader high frequency dispersion than others, so that seating positions and speaker orientations aren't quite so critical. Also, speakers with larger woofers tend to produce better sound than speakers with smaller woofers. Whether or not your mounting system can handle the weight of larger speakers is another consideration. In-ceiling speakers are another option.
Unfortunately, there is no one standard for how height speakers should be positioned or how the audio for them is generated. (Dolby has different recommendations than Audyssey, for example.) I know of only one movie which has had its audio intentionally mixed for use with home systems that include height speakers: The Expendables 2 was mixed for use with DTS Neo:X and 11.1 audio channels. See http://www.dts.com/corporate/press-releases/2012/11/the-expendables-2-first-blu-ray-to-feature-dts-neo-x.aspx
Aarghon likes this.
Selden
Selden Ball is offline
post #3 of 6 Old 09-22-2013, 08:29 AM - Thread Starter
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
thanks for your answer!
Well I was wondering if a center channel or any lcr speaker would do a better job than a wall mounted bookshelf...
And I didn't mean an horizontally oriented bookshelf, rather speakers designed to be horizontal, like centers or lcr vs standard vertical bookshelf ! Thought centers and lcrs could have a wider dispersion.
Yes, it's a sad thing that specific height channel mixes aren't common, but I think it will catch up, home cinema enthusiasts are only waiting for these mixes to buy additional speakers, and the industry wants that haha!
Have a nice day!
Aarghon is offline
post #4 of 6 Old 09-22-2013, 08:33 AM
Bond 007's Avatar
Quoted: 2371 Post(s)
Liked: 1907
Heights dont have to be anything special. Just get the best bookshelf speaker you can easily afford that is at least close to the same type as your front 3.
Aarghon likes this.
Licence to Kill
Bond 007 is offline
post #5 of 6 Old 09-22-2013, 02:53 PM - Thread Starter
Aarghon's Avatar
Quoted: 160 Post(s)
Liked: 380
Thanks bond! Well I could get a pair of energy rc minis for 100$, I think I'll go that way. So even if i'm not overly satisfied with dolby plIIz, it would have cost me only 100 bucks!
Aarghon is offline
post #6 of 6 Old 09-22-2013, 04:43 PM
Bond 007's Avatar
Liked: 1907
Sounds like a good plan. Those are pretty good speakers. If youre disappointed you can use them as back surrounds or in another room.
Aarghon likes this.
Licence to Kill
Bond 007 is offline
