Help with a small room - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-29-2013, 07:04 PM - Thread Starter
haysdb's Avatar
I have a 60" TV in a tiny room - roughly 10 x 10. My chair is flush against the back wall. To say this room is not ideal is an understatement but it's what I have.
My biggest problem is that the room is so live that I can't understand dialog. I'm limited in the permanent changes I can make so I'm looking at acoustic panels and curtains. It doesn't have to be pretty.
So, sources for heavy curtain and acoustic panels I can hang on the walls? I don't want any DIY solutions because I have limited tools with which to build frames.
-David
haysdb is offline
post #2 of 3 Old 09-29-2013, 08:20 PM
Scout's staff's Avatar
GIK Acoustics sell some pretty good starter kits. Adding a plush rug and curtains will help as well. Can you tell us where your speakers are placed - more specifically how low is your center speaker to the ground?
Scout's staff is offline
post #3 of 3 Old 09-30-2013, 12:12 AM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
If you are right on the back wall, I think you are going to need absorption right behind your head. What is your floor? Any other furniture in room?
lespurgeon is offline
