home media - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 10-15-2013, 02:37 AM - Thread Starter
rgreaves421's Avatar
hey guys/ladys
look I have been having trouble with home media and need some advice
so what im trying to set up is so I can watch movies ect in my bed room and not have to use a usb. but I want it wireless
so my pc is in the kitchen I have a  200mps WD power line plugged in.
then my router is in the lounge room with the other power line plugged in to that
then in my bed room I have the WD tv hooked up to the tv running wireless to the router.
what am I doing wrong some of my movies still go all messed up  any idea?
rgreaves421 is offline
post #2 of 2 Old 10-15-2013, 09:57 AM
JBWIII's Avatar
Liked: 43
Some of the movies are messed up? If some work and some don't, then it could be that the WD TV cannot play certain files, or the combination of the powerline ethernet and the wireless is just too slow for high-resolution files. You might try, as an experiment, hooking these devices to each other using ethernet cables and seeing if that solves the problem. If it does, then you know that it's a bandwidth issue.
JBWIII is offline
