Design opinion? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 10-19-2013, 09:30 AM - Thread Starter
chrisbratton22's Avatar
Here is the layout I'm working with. What do you guys think. What would be the largest screen I can use?
Thanks, Chris Media Room.JPG 75k .JPG file Media Room Layout.JPG 101k .JPG file
ID:	72780   Click image for larger version
Name:	Media Room Layout.JPG
chrisbratton22 is offline
post #2 of 6 Old 10-19-2013, 08:39 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
About a 130" diagonal screen would be max I think - Just under 10 feet wide. I would put eye distance from the front row at screen width (8 to 10 feet, whatever you end up with with for screen width). To me, any closer is just too close. A 130" screen takes a powerful projector.
lespurgeon is offline
post #3 of 6 Old 10-24-2013, 11:53 AM - Thread Starter
DO you think the new JVC pro will be bright enough at 1600 lumens?
post #4 of 6 Old 10-24-2013, 01:17 PM
nolimits76's Avatar
Nice layout!  Love the pool table with bar stools and bar ledge setup!
No idea on the projector.  Just wanted to say I think you are heading the right direction.
nolimits76 is offline
post #5 of 6 Old 10-25-2013, 10:03 AM
gec5741's Avatar
Quoted: 202 Post(s)
Liked: 92
Maybe look at the new epson 5030ub. I'm not sure what your budget is for the PJ but for around 2500 bucks its suppose to be one of the brightest and best picutures out. This model just came out to replace the 5020ub wich from what I hear was a light cannon. I guess for the price range the 5030ub also is suppose to be great for 3d in it's price range. There is a big thread over in the PJ forum about it. That's what I'm leaning towards when I finally am ready to buy one. Hopefully this summer.
gec5741 is offline
post #6 of 6 Old 10-27-2013, 10:13 AM - Thread Starter
My price range would be up to about 12K for the projector.
