AustinJerry's Set-Up - AVS Forum | Home Theater Discussions And Reviews
 21Likes
post #1 of 43 Old 10-21-2013, 08:14 AM - Thread Starter
AustinJerry's Avatar
Quoted: 5963 Post(s)
Liked: 3329
The purpose of this thread is to document my listening room, equipment, and the listening room's audio performance.  It is not intended for feedback, although if you have any questions, I will be happy to answer them.
Equipment List
Listening Room Layout and Pictures
Note: Layout is not to scale.
Room Treatments:
2'x4' Bass Traps (26 total, 4 RealTraps Mini-Traps, 20 GIK 244 Bass Traps, 2 GIK Monster Bass Traps)
5 GIK 244 bass traps have scatter plates (two each on side wall 1st reflection points, and one in rear corner)
2'x4' Full-Spectrum wall panels (2 total, GIK 242 Panels)
AustinJerry is online now
post #2 of 43 Old 10-21-2013, 08:14 AM - Thread Starter
Liked: 3329
Equipment List
Speakers (7.1 configuration):
Marantz 8802A
MiniDSP DDRC-88A with Dirac Live, with BM Plug-in
MiniDSP 2x4 balanced
Emotiva XPA-7
Oppo BDP-103
DirecTV HR-24 (2)
DirecTV AM-21 OTA
AppleTV 3
Sonos Connect (ZP-90)
Sony XBR75X940D UHD/HDR Flat Panel
Sanus LL22-B1 wall mount
Sony FMP-X10 4K Media Player
Darbee Vision DVP-5000S
Wired4Sound Remedy
How I spent my AV budget:
Spazdoc and johnnymacIII like this.
post #3 of 43 Old 10-21-2013, 08:14 AM - Thread Starter
Liked: 3329
Room Response Characteristics (updated August 21, 2014)
Measured using REW 5.01 beta 17, UMIK-1 USB mic.  Noise floor measured using RTA is 50dB.
Frequency response:
Modal ringing:
Impulse Response:
Distortion:
johnnymacIII likes this.
post #4 of 43 Old 10-21-2013, 08:14 AM - Thread Starter
Liked: 3329
Analysis - Benefits of Multiple Subwoofers
The purpose of this post is to show the interaction of multiple subs in the listening environment, and how careful placement and tuning can result in a significant improvement in bass response.  The subs used in this analysis are four Hsu Research ULS-15 sealed subs.  The subs are placed in the listening room as per the diagram in the first post in this thread.  The two front subs are at the 1/4 and 3/4 spots along the front wall, and the two rear subs are collocated at approximately the center of the back wall.  The two front subs are equidistant from the MLP, and are connected to the sub1 input on a MultEQ XT32 AVR with Sub EQ HT.  The two rear subs are also approximately equidistant from the MLP, on the Sub2 input on the AVR.  The two front subs are gain-matched to each other, and the two rear subs are gain-matched to each other.  However, the level of the rear subs is 5dB lower than the two front subs, because they are significantly closer to the MLP.
The measurement of the subs independent of each other, and as front and rear pairs, reveals that the in-room response (without room correction) is not very smooth.
Individual subs:
Sub Pairs:
However, when all fours subs are driven at the same time, we start to see advantages in the summed response:
And Audyssey room correction puts the final smoothing on the response:
And finally, combined response including center channel:
This analysis clearly shows the benefits of multiple subs in the listening environment.
To add some historical perspective, here is what the bass response looked like in October 2011, when I had only two subs, and no bass treatments in the listening room.
As you can see, it has been a long journey, and a successful one.
Alan P, ahblaza, mthomas47 and 2 others like this.
post #5 of 43 Old 10-21-2013, 08:15 AM - Thread Starter
Liked: 3329
<Reserved>
post #6 of 43 Old 10-21-2013, 08:15 AM - Thread Starter
Liked: 3329
<Reserved>
post #7 of 43 Old 11-01-2013, 02:40 PM
kbarnes701's Avatar
Quoted: 6740 Post(s)
Liked: 5058
kbarnes701 is offline
post #8 of 43 Old 11-09-2013, 02:31 PM
7channelfreak's Avatar
Quoted: 286 Post(s)
Liked: 189
That has to sound incredible.
7channelfreak is offline
post #9 of 43 Old 11-19-2013, 12:32 PM
Roger Dressler's Avatar
Quoted: 1509 Post(s)
Liked: 705
Hi Jerry,
Just curious, why do you have the L/R at +/- 45 degrees? That's pretty wide (usually 30 is plenty). Considering you also have wide speakers (at +/- 65) it does not seem you'd be lacking for width cues.
Deadwood Atmos theater [HTOM]
AV7702 Atmos 7.4.4, SSP-800 PLIIx 7.4
Aerial Acoustics 7B/CC3B fronts, B&W CWM8180 surrounds, Tannoy Di6 DC heights, Hsu ULS-15 subs
Roger Dressler is offline
post #10 of 43 Old 11-19-2013, 01:50 PM - Thread Starter
Liked: 3329
Originally Posted by Roger Dressler View Post
Hi Jerry,
Roger,
Perhaps you are miss-interpreting my drawing.
The front speakers are at an angle of 27.3 degrees, and the Wides are at an angle of 51.2 degrees, which is actually a narrower angle than the recommendation.
post #11 of 43 Old 11-19-2013, 03:04 PM
Liked: 705
Originally Posted by AustinJerry View Post
Roger,
Oops, yes, I did not notice the angles! I just plopped it into Corel and measured them. The drawing is, as they say, "not to scale." wink.gif
Sorry for my confusion.
post #12 of 43 Old 11-19-2013, 04:01 PM - Thread Starter
Liked: 3329
No harm done.  It is just a PowerPoint drawing, so no way to draw it to scale.  I used to use AutoCAD when I was working, but don't want to spend the money for a personal license.  If you know of a good consumer-class (read:  inexpensive or free) CAD program, I would welcome the recommendation.  In the meantime, I determine angles by using a spreadsheet that calculates the angles from the distances of the legs of the triangle.
post #13 of 43 Old 11-19-2013, 06:28 PM
Liked: 705
If you like to have the option for 3D rendering, try SweetHome3D. I found it much easier than Sketchup.
post #14 of 43 Old 11-20-2013, 11:00 PM
Liked: 705
Here's your room translated to SweetHome3D
The project's file: Jerrys Room.zip 144k .zip file
post #15 of 43 Old 11-21-2013, 06:46 AM - Thread Starter
Liked: 3329
Wow, I am impressed.  I need to download that software.  Thanks!
post #16 of 43 Old 12-04-2013, 11:52 AM
marcfarmen's Avatar
That is great. I am building mine now in Sweet Home it rocks!
marcfarmen is offline
post #17 of 43 Old 12-31-2013, 01:48 PM
Wireless member
pepar's Avatar
Quoted: 807 Post(s)
Liked: 471
I am IMPRESSED as well!!! Sweet, indeed!
"Veni, vidi, vino!"
(I came, I saw, I drank wine!)
pepar is offline
post #18 of 43 Old 12-31-2013, 03:43 PM - Thread Starter
Liked: 3329
Yes, I still owe it to Roger to learn how to use that software. So many things on the to-do list!
post #19 of 43 Old 01-23-2014, 02:43 PM
marcfarmen's Avatar
I have finished my drawings. Even put my wife in one. Take a look.
I have posted the source files as well.
http://files.snowsoftware.com/files.zip
Frohlich, Spanglo, NODES and 1 others like this.
post #20 of 43 Old 01-30-2014, 06:50 AM
dRwOOD73's Avatar
Great Looking (& sounding ) room, came here from the link in your sig & your suggestion in the REW thread about a month ago - trying to get caught up as we speak so I may join the discussion.. just started measuring a few weeks ago after a lot of lurking & learning..
dRwOOD73 is offline
post #21 of 43 Old 03-18-2014, 08:22 PM
ai_0301's Avatar
Very good set-up ! I like it.
ai_0301 is offline
post #22 of 43 Old 05-22-2014, 03:54 PM
Spanglo's Avatar
Quoted: 491 Post(s)
Liked: 435
Great setup and seeing those graphs is very helpful and encouraging. Nice to see such good response after all the hard work you put in.
Big thanks for recommending the sweethome3d program... what great software. I was able to model the before and after of my room in no time. So much better than google sketch. Thanks again.
PSN - Hapi_Kilmore_v3
My 6.4.4 Living Room HT
Spanglo is offline
post #23 of 43 Old 06-04-2014, 10:02 AM
hatlesschimp's Avatar
Quoted: 393 Post(s)
Liked: 351
Hey Austin, Nice work with the speakers! Just wondering if you can help me out with what you think is the best settings for 3D blu rays on the Sony x900.
Cheers Mate!!!
hatlesschimp is online now
post #24 of 43 Old 06-10-2014, 09:52 AM
Schlemstar's Avatar
Quoted: 28 Post(s)
Going to have to try this software as I have gotten some comments about my build thread not having a layout. Thanks!
Schlemstar is offline
post #25 of 43 Old 01-23-2015, 11:51 PM
SherazNJ's Avatar
Quoted: 1210 Post(s)
Liked: 144
Just saw your dedicated thread now. Very nice. Do you by any chance have REW graphs (frequency/ETC/...) before/after treatment to show the difference they brought?
Also where in the pics you have following placed
2'x4' Full-Spectrum wall panels (5 total, GIK 242 Panels)
thx.
SherazNJ is offline
post #26 of 43 Old 01-27-2015, 03:16 PM
steve1971's Avatar
Quoted: 478 Post(s)
Liked: 421
Damn AustinJerry that is one beautiful setup you have. I would have bought the X900A myself but went with its 55inch sibling the 55W900A which like the X900A is a beautiful tv. IMHO the 2 best tv's made by Sony. Again though very nice setup.
steve1971 is offline
post #27 of 43 Old 02-15-2015, 10:41 PM
Spazdoc's Avatar
Quoted: 42 Post(s)
Beautiful set up.
I was wondering if you might be able to share your process in choosing acoustic treatments. I am in the early stages of planning acoustic treatments, and am trying to figure out what I need.
Did you try to place as many bass traps as you could, given that you have 4 potent subs, or did you follow the REW measurements, or something else?
Spazdoc is offline
post #28 of 43 Old 02-16-2015, 06:13 AM - Thread Starter
Liked: 3329
Originally Posted by Spazdoc View Post
Beautiful set up.
Treatments accomplish two things--they reduce bass resonance, and they tame reflections in the spectral region. The guidelines for treatments to control bass resonance are to 1) choose treatments designed specifically for the longer hass frequencies (which are generally thicker), and 2) to place the treatments in the most effective locations, at the intersection of multiple surfaces, e,g. room corners, wall to ceiling, etc. Also, the more traps, the more effective the resonance control.
Treatments for spectral reflections are different. The treatments themselves must be full-spectrum treatments, and they are placed at spots specifically associated with reflections. You can analyze room reflections using the REW ETC measurement.
There are threads here on AVS that provide more specific guidance on effective room treatment.
Spazdoc likes this.
post #29 of 43 Old 02-16-2015, 09:27 AM
Spazdoc's Avatar
Quoted: 42 Post(s)
Thanks. The trouble with many of the posts on here is that often the advice is specific for a that applicaiton, rather than unifying ideas. Although I have been reading up on hometheatershack, the guide that you have in your sig ( Getting Started with REW: A Step-by-Step Guide ) has been the most helpful and concise guide for using and understanding the REW I could find. Thank you very much for putting it together.
AustinJerry likes this.
Spazdoc is offline
post #30 of 43 Old 04-01-2015, 11:46 PM
sdrucker's Avatar
Quoted: 613 Post(s)
Liked: 407
Jerry,
A technical question for you. To calculate the LF/RF speaker angles, did you do the following. Assuming adjacent right angle triangles at MLP on the chart in post #1 , did you compute:
Adjacent = 108"/2 = 54" (i.e. 1/2 the distance between your LF and RF speakers, assuming your center channel and MLP represents 0 degrees)
Hypotenuse = 108" (distance from center of LF to MLP)
Angle (360 degrees) = Inverse cosine of (54"/108")= 60
To put on a +/- 180 degrees scale, that becomes 60/2 = 30 degrees
Note that this is the physical angle, not complicated by things like differences in speaker level or calculation of electronic delays.
I think this is right, but just confirming to do some room brainstorming of my own.
Audio Gear: Trinnov Altitude 16/24, NAD M27 and Wyred4Sound MMC-7 amps
Display: Panasonic VT50, Lumagen Radiance Mini. Misc.: Oppo 103, Samsung K8500 UHD player, JRiver
Speakers: PSB Imagine T2, Center, Imagine T Wides and Side Surrounds, Imagine S rear surrounds,
PSB Imagine XA Dolby AE Speakers (4), HSU ULS-15 subs (2) - 9.2.4
sdrucker is online now
Denon Avr 4520ci Receiver , Emotiva Xpa 3 Amplifier , Oppo Bdp 93 Blu Ray Player , Sonos , Sony Xbr 65x900a 65 Inch 1080p 120hz 3d Led 4k Ultra Hdtv , Darbeevision Darblet Hdmi Video Processor
