Placing TV on edge of wall mount - AVS Forum | Home Theater Discussions And Reviews
Old 11-01-2013, 12:09 PM - Thread Starter
jtk16's Avatar
Hello everyone. First off, I apologize as this situation seems to have been discussed a lot; however, I couldn't seem to find the answer to my question in my searches.
Question: if I attach the wall mount to two studs, is it safe to place the tv on the edge of the mount?
Additional info:
In the attached pic, the 3 studs (24" apart) are marked by small pieces of tape. I've also marked the outline of the VESA holes as shown by the large square and you can see the position of the mount if it were to be attached the center and right studs. Is this ok? Should I attach the mount to additional drywall anchors? Or is this just a bad idea?
From my previous searches, most people recommend installing a plywood backing. However, if I place plywood across the 3 studs, then that will be wider than my 40" Samsung LCD. Also, it would cover the existing outlets.
Your thoughts/suggestions would be greatly appreciated. Thanks in advance!
-JTK
jtk16 is offline
Old 11-01-2013, 12:23 PM
Colm's Avatar
Liked: 94
What do the manufacturer's instructions say?
Colm is offline
Old 11-01-2013, 12:38 PM - Thread Starter
jtk16's Avatar
The instructions don't say anything about location of the tv on the mount. Regarding mounting, it just says to place the hooks securely onto the top lip of the mount.
Also, if this matters, the mount is a Cheetah APTMM2B purchased from Amazon.
jtk16 is offline
Old 11-01-2013, 12:45 PM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
If the mount is secure to the wall it should not matter
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
Old 11-01-2013, 01:21 PM
Colm's Avatar
Liked: 94
Originally Posted by jtk16 View Post
...it just says to place the hooks securely onto the top lip of the mount.
Well then, you should be good to go.
Colm is offline
Old 11-01-2013, 08:11 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
40" TV? What's it weigh? Probably not a lot. I'd use the center stud and a couple of Togglers.
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
Old 11-01-2013, 10:02 PM - Thread Starter
jtk16's Avatar
Hey--thanks for the responses. I went ahead and attached the mount to the center and right studs and placed the tv on the left edge of the mount. But there's still the problem of the mount showing. So, I'll either think of a solution to cover the mount, or might try olyteddy's suggestion about the Togglers (TV is about ~30 lbs). Or, use this as an excuse to buy a larger tv!
jtk16 is offline
Old 11-02-2013, 05:14 AM
airscapes's Avatar
Quoted: 350 Post(s)
Liked: 285
Center stud and duct tape on the ends would hold that just fine (just kidding) If it is mounted in a stud in the center, any kind of dry wall anchors will suffice on the ends, but I do love the Hiliti Togglers (over kill for this applications )
Doug
