Quite beverage cooler/under counter refrigerator? - AVS Forum | Home Theater Discussions And Reviews
Old 11-07-2013, 07:04 PM - Thread Starter
kostia's Avatar
Any suggestions for under counter beverage cooler (good enough for beer) or refrigerator that is quite enough for bar/entertainment area?
kostia is offline
Old 11-08-2013, 10:32 PM
AnnapolisSony's Avatar
Quoted: 93 Post(s)
Liked: 136
We are installing this in our media room in another month or so. Make sure you go with one that has the venting in the FRONT or they tend to "go up" quicker. You get what you pay for with refrigerators. smile.gif
http://www.lowes.com/pd_363325-13247-BC100GS_0__?productId=3448632&Ntt=haier+beverage+center&pl=1&currentURL=%3FNtt%3Dhaier%2Bbeverage%2Bcenter&facetInfo=
Good luck!
Displays: Epson 5030UB | 100-inch Elite Sable Fixed Mount | Samsung UN46F5500 LED TV
Sources: Yamaha RX-A1010 | Emotiva XPA-3 | OPPO BDP-103 | Panamax M5300 | Pro-ject Carbon Debut Turntable | Sonos Connect | Apple TV
Speakers: Polk 265-RT (L/R) | Polk 255C-RT (C) | Polk 65RT (L/R SUR) | Polk RC80i (L/R REAR SUR) | Subwoofers: PSA XV-15se X 2
Controls:Wall-mounted iPad AVS Forum Thread: 904WMC Media Room Thread
AnnapolisSony is offline
Old 11-08-2013, 10:47 PM
lespurgeon's Avatar
Quoted: 31 Post(s)
Liked: 52
Best if you can listen to them. I had a Sears/kenmore years ago that was pretty quiet. Our current wine fridge drives me crazy, since it is in the bedroom closet.
lespurgeon is offline
Old 11-11-2013, 06:22 AM - Thread Starter
kostia's Avatar
If venting is in the back but there is plenty of "extra" room in the back would that still create a heat build up and make it run more? I was thinking that even with went in the back I would create venting space on the bottom for the air to go out from with flow to back and then hopefully out in the front? Over the weekend I found that Magic Chef - 3.6 Cu. Ft. seems to be pretty quite with good reviews and pretty cheap.
It is a refrigerator, but maybe that is a better option anyway?
kostia is offline
