Low profile, articulated wall mounts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 11-09-2013, 09:42 AM - Thread Starter
jackaninny's Avatar
I need a good articulated wall mount for a 32" display. Low profile if possible and nice, smooth movement.
jackaninny is offline
post #2 of 3 Old 11-10-2013, 04:38 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
most articulated mounts will add at least 2.5" to the depth of the display when fully collapsed. This model at 1.5" is the shallowest I know of. Won't be the cheapest mount you can find, but Chief makes top quality mounts with nice finishes, smooth movement and a huge variety of hardware to accommodate most any display.
http://www.chiefmfg.com/Series/TS218S
If you want the ultimate in low profile, check out their in wall accessory box for this mount. Takes a good sized hole in your wall, and the right structural conditions to be utilized, (14.5" between studs, 4" of depth, no other obstructions in the cavity) but lets the arms fold into the wall, plus provides mounting knock outs for electrical and source cabling.
http://www.chiefmfg.com/Products/TA502
underachiever extraordinaire
weaselfest is offline
post #3 of 3 Old 11-10-2013, 04:50 PM
JimShaw's Avatar
Quoted: 335 Post(s)
Liked: 359
OmniMount makes a good product.
Low Profile for 32" is 1.8"
http://www.omnimount.com/products/tv_wall_mounts/full_motion/ulpc-s/
8.3 Surround, protected by APC H15
Speakers: SpeakerCraft: 6 AIM8 Fives & 2 TIME Fives used as Wides
Woofers: SVS PB13-Ultra (1), HSU MBM-12 MK2 (2)
Samsung UN78JS9500,. LG OLED55E6P
Oppo UHD-203 player, Denon X7200WA, Harmony 1100, Harmony Elite, 9 Noctua cooling fans
JimShaw is offline
