basement build - AVS Forum | Home Theater Discussions And Reviews
Old 11-12-2013, 02:05 PM - Thread Starter
kryolla's Avatar
Im finishing my basement and using part of a room to put a 100 inch screen. Should I put a tv stand in the front so all I have to run to the back wall is hdmi and the 2 rear speakers? Im putting up drywall soon and Im not sure what I need for the speakers like should I use a wall plate or should I just run the speaker wire and poke a hole same thing for sub. Should I run the blue conduit? Im usimg axiom audio on wall speakers.Thanks
kryolla is offline
Old 11-12-2013, 03:25 PM
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
I'm in the process of a build myself and these were all things I asked myself as well. I was going to run my hdmi and all to the front of the room and use some sort of tv stand for all my equipment. But I decided to build an inwall rack on the side of my room since it backed up to my utility room. That's next on my list. I have limited space on my screen wall as far as hieght goes so didn't want to take up more then I needed. As far as speaker lines go I'm just going to be using a wall plate and drilling a hole for he cable. You could terminate them but for me as for the speakers go I'm not concerened really with that. Or you can use a pass through plate for your sub and speaker lines. Basically a plate with a precut hole. If it were network lines and HDMI i'd probably terminate with keystone jacks from monoprice. I would also run some sort of flex conduit along with any cables for future pulls. Leave out your current cables though. Just add in a few pull strings in the conduit runs.
gec5741 is offline
