Projector for room size? - AVS Forum
post #1 of 3 Old 11-18-2013, 06:31 AM - Thread Starter
cove1970's Avatar
Hi All,
I have decided to get into the game and have been looking at the Optoma 25e and BenQ 1070 as options but am a bit lost on a few things.  My room is 18 feet long and projection area is 10 feet wide so my max screen size would be between 90 and 100 inches diagonal.  Perfect world is that the projector is shelf mounted on the back wall.  It appears that I have to have the projectors fairly close to the screen. to get the size I need..questions:
1). If the projector is close to the screen, Should I be concerned that the image will be too bright? ( Room has no windows)I have tried the calculator at projector central and the lumens are so high when these projectors are 8 feet from the screen.
2)  The optoma has no vertical shift...is that a big concern? ( I could ceiling mount)
3) Any budget projectors that would allow me to project from 18 feet away and get a 100 inch pic?
Thanks so much- I may have over complicated things and confused myself :0
Mike
cove1970 is offline
post #2 of 3 Old 11-19-2013, 09:52 PM
lespurgeon's Avatar
Liked: 40
The Epson 8350 has huge mounting range - should be able to shelf mount at back, or ceiling mount.
You would probably get better advice over on the projectors<3k board.
lespurgeon is offline
post #3 of 3 Old 11-20-2013, 06:41 AM - Thread Starter
cove1970's Avatar
Thanks for the suggestion and advice on where to post - very much appreciated.  Mike
cove1970 is offline
Benq W1070 3d Ready Dlp Projector 1080p Hdtv , Optoma Hd25e 2800 Ansi Lumens 3d Home Theater Projector
User Tag List
