Best budget rack? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 12-03-2013, 03:59 AM - Thread Starter
koturban's Avatar
Quoted: 225 Post(s)
Liked: 124
I'm looking for a no frills rack to relocate my equipment from my family room to my basement.
It doesn't require any fancy sliders or pivots, but I would like to be able to wall mount it such that front and back are free.
koturban is offline
post #2 of 3 Old 12-03-2013, 04:13 AM
TempestGuy's Avatar
I don't have a specific recommendation for you, but here are a couple of sources as a place to start:
http://www.standsandmounts.com/
http://www.wayfair.com/filters/Audio-Racks-and-Stands-C414565.html?filter=ClID~7|1230
TempestGuy is offline
post #3 of 3 Old 12-03-2013, 09:09 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
Most 'in-wall' racks sit on a stand or the floor, or have casters. Wall mount racks are mounted to a sturdy wall, and swing open to access the rear.
I would suggest an old used cheap server cabinet on casters, next to a wall. Check craigslist and university surplus. Local eBay search may also be fruitful (i.e. within 100 miles of your zip code).
You can upgrade at any time, and learn a ton about racks in the interim, e.g. what size rack you really need, how shelves and rack ears work, how to mount stuff that doesn't need a rack.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
