TooFast's Room 7.4 Setup - AVS Forum | Home Theater Discussions And Reviews
 4Likes
  • 2 Post By toofast68
  • 1 Post By toofast68
  • 1 Post By SeanKosmann
post #1 of 10 Old 12-31-2013, 11:36 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Below is a bit about my Home Theater.
Although it is a "dedicated theater", it is somewhat unconventional in that it is an "open concept" theater. The only way I could get this theater built without causing a war in my house was to build using this approach. HATS OFF TO BIGmouthinDC for helping consult on the project and even stopping out while on route to another of his famed theaters.
Drawn is the whole space and the dedicated "theater room"
Here is the initial readings of REW - EDIT - this graph is not accurate, as I was sending the LFE signal twice (I think) - I will try to update soon!
toofast68 is offline
post #2 of 10 Old 12-31-2013, 11:36 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Equipment Listing:(to be continued)
Denon AVR 6200W
  • 7.2.4 Channels
Epson Powerlite Pro Cinema 6010 3d 1080p Projector
  • Native Brightness - 2400
  • Contrast - 200,000:1
  • Lens Shift - Up/Down/Left/Right
Panasonic DMP-BDT220 Blu-ray Player
  • 3D
  • Integrated WiFi
  • Dolby Tru HD
Da-Lite Tensioned 120" Screen 16:9
  • Recessed Electronic Drop Down Screen
  • Tab Tensioned
  • Da-Mat White Material Gain 1.0 (although research shows it might be closer to 1.3)
  • 160 degree viewing angle
New Speakers Almost Ready
Main Left/Right - PSA MT-110
  • 2 way, audiophile loudspeaker
  • 1" titanium compression driver
  • Cast aluminum exponential horn
  • 10" high efficiency woofer
  • Audiophile grade crossover - completely designed in house
  • frequency response 70JHz-18,000 Hz (±3dB)
  • 8-ohm impedance
  • sensitivity 95 dB 1W/1M
  • Power Handling 175 watts
Center - PSA MT-110c
  • 8-ohm impedance
Front Wides - Infinity Primus P152
  • frequency response 58-20,000 Hz (±3dB)
  • 8-ohm impedance
  • sensitivity 88 dB
  • handles up to 100 watts
  • 3/4" MMD™ tweeter
  • 5-1/4" MMD woofer
Surrounds - Mirage Omnisat Omnipolar
  • frequency response 110-20,000 Hz (±3dB)
  • Omnipolar® technology for 360° sound dispersion
  • 3/4" PTH™ tweeter
  • 2-3/4" Titanium Deposit Hybrid polypropylene woofer
  • 8-ohm impedance
  • sensitivity 87 dB
ATMOS Speakers 4 (TL/TR/RL/RR) - Mirage Nanosat Omnipolar
  • 3/4" PTH™ tweeter
  • 8-ohm impedance
  • sensitivity 87 dB
Sub Woofer;s - 4 Klipsch RW-12d - 2 front / 2 rear
  • frequency response 24-120Hz +/-3dB
  • 12" Woofer
  • AMP BASH digital hybrid
  • MAXIMUM ACOUSTIC OUTPUT - 116dB @ 30Hz 1/8 space, 1m
  • Watts -FTC Rated Power: 350 watts continuous @ <2% THD / Dynamic Power*: 825 watts
Samsung UN40EH6030 - Bar TV
  • 40 Inch
  • 1080P 120Hz LED (3D only because it had it)
Panasonic VIERA TC-P65ST30 - Theater Supplemental TV (Sports/Games/Kids Everyday Viewing)
  • 65 Inch
  • 1080P 600Hz Plasma (3D only because it had it)
Logitech Harmony 900 Universal Remote
Xbox
PS3
Polk Audio Atrium 6 Speakers (Zone 3 Patio)
  • all-weather enclosure
  • 5-1/4" woofer, 1" aluminum dome tweeter
  • PowerPort® technology for better bass response
  • frequency response 50-27,000 Hz
  • sensitivity 90 dB
  • 8-ohm impedance
RECENTLY RETIRED EQUIPMENT
Onkyo 809 with Audyssey MultiXT
  • 135 W/Ch, 8 ohms, 20 Hz20 kHz, 0.08, 2 channels driven, FTC
  • 7.2 Channels
  • THX Certification - Select2 Plus
  • 8 HDMI Inputs and 2 Outputs with support for 3D and Audio Return Channel; Network Capability
  • Direct Digital Connection of iPod/iPhone via Front & rear USB ports
  • 135 W/Ch (8 ohms, 20 Hz?20 kHz, 0.08%, 2 channels driven, FTC) 145 W/Ch (8 ohms, 1 kHz, 0.7%, 2 channels driven, FTC)
Main Left/Right - Infinity Primus P362
  • frequency response 38-20,000 Hz (±3dB)
  • 8-ohm impedance
  • sensitivity 93 dB
  • handles up to 200 watts
  • 3/4" MMD tweeter
  • 4" MMD midrange
  • dual 6-1/2" MMD woofers
Center - Infinity Primus PC350
  • frequency response 80-20,000 Hz (±3dB)
  • 8-ohm impedance
  • sensitivity 91 dB
  • handles up to 150 watts
  • 3/4" MMD™ tweeter
  • dual 3" MMD midranges
  • dual 5-1/4" MMD woofers
witchdoctor and oneeyeblind like this.
post #3 of 10 Old 12-31-2013, 11:37 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Acoustical Treatments
Main Theater Wall
  • 100% Treated
  • Linocoustic 1/2" over 3 1/2" Rockwool
  • Covered by GOM Black 408
Front Bass Traps
  • Full Length Corner Traps, floor to ceiling
  • "Pink Fluffy" material
Rear Wall Traps
  • 3.5" Roxul with 2.5" Air Gap x 3
Ceiling Cloud for 1st Row 1st Reflection
10' x 2.4' x 3.5" thick, hanging 6 inches off ceiling. Simply Amazing.
Center Pre Ceiling Cloud
Center Post Cloud - Nearly a 15dB reduction in 1st Reflection.
What is next ?
Better Rear Corner Bass Traps
oneeyeblind likes this.
post #4 of 10 Old 12-31-2013, 11:37 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
post #5 of 10 Old 12-31-2013, 11:37 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
post #6 of 10 Old 12-31-2013, 11:37 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
post #7 of 10 Old 01-02-2014, 09:54 AM
SeanKosmann's Avatar
Looks like a great concept... what program did you use for the diagrams?
SeanKosmann is offline
post #8 of 10 Old 01-02-2014, 09:56 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Thanks...I used www.floorplanner.com
it is not the most flexible, but when I started it was all that I found.
We changed the plan about 10 times, so in the end it all worked out.
post #9 of 10 Old 01-02-2014, 09:58 AM
Haha nice, I was actually just reading another forum that mentioned... SweetHome3d.com might be worth checking out to give you a different look on the dimensions. Looks like you have a pretty great layout to work with. If you every wanted to get crazy, you could ditch the billiards and close off the wall by the bar, turn the HT 90 degrees and have enough seats for a soccer team wink.gif
post #10 of 10 Old 01-02-2014, 10:08 AM - Thread Starter
toofast68's Avatar
Quoted: 485 Post(s)
Liked: 130
Funny, I actually wanted to do that...but in all reality our "main living space" in our house is relatively small, and we really needed the "family room" living space.  In fact, we have NOT installed the pool table and we've optioned for additional LOUNGE type seating, etc. for pre-movie hanging out.
