lighted liqour shelves - AVS Forum | Home Theater Discussions And Reviews
Old 01-26-2014, 08:06 AM - Thread Starter
southerngurl256's Avatar
Need instructions on how to build led lighted liquor shelves for man cave.
southerngurl256 is offline
Old 01-27-2014, 01:57 PM
empinball's Avatar
Will post better photos after they are wall mounted and faced with brushed aluminum.
southerngurl256 likes this.
empinball is offline
Old 01-27-2014, 08:14 PM
dictator92's Avatar
Those are sweet! You just gave me a great idea .
dictator92 is offline
Old 01-28-2014, 08:01 PM
mkeyes22's Avatar
Very cool idea. Did you have to scuff the acrylic or was it already a simi transparent ? It results in a very cool look
mkeyes22 is offline
Old 01-28-2014, 08:35 PM
empinball's Avatar
I couldn't find opaque acrylic so I bought some krylon glass frosting spray initially but didn't use it. The acrylic sheet came with white plastic protective coating on each side. I removed the top layer that the bottles would most likely scuff anyway and left the bottom layer on (inside the shelf cavity) to diffuse the led's. I'm very happy with the results.
Old 01-30-2014, 09:02 AM - Thread Starter
thanks!
Old 01-31-2014, 12:32 PM
empinball's Avatar
Updated photos
Old 01-31-2014, 12:39 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 373
Very nice. Do you have any photos of the light strips in the box or how you're feeding power into them?
BllDo is offline
Old 01-31-2014, 04:42 PM
empinball's Avatar
I'm just using an led strip light kit from Amazon. The lights have adhesive backing and I placed them in the center of the shelf cavity.
The lights come with their own power supply. Just need an outlet to plug into, which i installed before hanging my cabinets.
They also come with an IR remote and sensor which you can see under the corner of the cabinet.
BllDo and mkeyes22 like this.
Old 02-05-2014, 07:25 AM
mkeyes22's Avatar
That is awesome! Thanks for adding the detail photos.
mkeyes22 is offline
Old 02-14-2014, 01:20 AM
value's Avatar
Have a dumb question for guys running a bar setup in their home theater. Do you get any bottle rattling during music/movies??
value is offline
Old 02-14-2014, 10:10 AM
gec5741's Avatar
Quoted: 200 Post(s)
Liked: 91
Very nice!
I wonder do they make led light stips that have a battery pack of some sorts so you don't have to have them plugged in to an outlet?
gec5741 is offline
Old 04-17-2014, 08:17 AM
cbehr1's Avatar
Would these be dimmable by any chance?
cbehr1 is offline
Old 04-18-2014, 07:33 PM
ADDUpstate's Avatar
Most of the led strip kits like the one above are dimmable and come with a remote.
I've ordered many kits and strips from barlighting.com and they have been great with service shipping and product.
ADDUpstate is offline
