Help with projecting images on ground - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-10-2014, 01:26 PM - Thread Starter
user857's Avatar
I'm in need of a ceiling-mounted projection system, for displaying images and video on the ground. I think the easiest way of describing what I want to do is to share this link: http://www.gesturetek.com/gesturefx/productsolutions_groundfx.php
My working area is a rather large warehouse-size room, with high ceilings (20-30ft). I'd like the ground projection area to be at least 4m x 4m (the bigger the better). I'm not too familiar with projection systems, but I think my main concern would be light intensity and image quality, as light intensity drops proportional to radius^2.
If anyone can point me to the best projector capable of handling this task, or a DIY tutorial for this, or any other ideas in general regarding this project, I would appreciate it. I can provide more details if needed.
Thanks all, I appreciate any help!
user857 is offline
post #2 of 9 Old 02-10-2014, 06:36 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
The other factor you may want to consider is the orientation of the projector. Most won't tolerate being tilted more than 10-15 degrees out of horizontal before they start having issues with heat dissipation. If you plan on running this setup more than an hour or so at a time and not be buying bulbs every couple of hundred hours, I'd look at using a mirror with any conventional, moderately priced projector. There may be some unique model that offers this feature for a reasonable price, but I suspect you will need to be prepared for some major sticker shock.
underachiever extraordinaire
weaselfest is offline
post #3 of 9 Old 02-10-2014, 07:03 PM - Thread Starter
user857's Avatar
Hey, thanks for the reply. I had not thought of that, actually, thanks! Any recommendations regarding projector types? Budget is probably in the low $thousands.
user857 is offline
post #4 of 9 Old 02-10-2014, 07:34 PM
ch1sox's Avatar
Quoted: 317 Post(s)
Liked: 113
I've seen some board game players setup a projector/mirror combo to have it show in the ground. Might be something worth looking into: http://m.youtube.com/watch?v=lX7lmMKIFKA
ch1sox is offline
post #5 of 9 Old 02-11-2014, 12:44 AM - Thread Starter
user857's Avatar
Very interesting. I'm a bit concerned about the size of the projections I'm seeing here however. Any ideas if a 4m x 4m area is remotely possible? Thanks!
user857 is offline
post #6 of 9 Old 02-11-2014, 05:36 PM
weaselfest's Avatar
Quoted: 46 Post(s)
Liked: 41
better find out exactly how high you can mount that projector. To achieve a 4m vertical screen with a most projectors is going to take a throw distance of well over 20'. check out projector central and start plugging in models you can afford. The other worry with this long throw distance is having any light left by the time you hit your "screen" You're gonna need as much light output as you can afford to have any resolution even with lowered ambient light levels.
post #7 of 9 Old 02-11-2014, 07:39 PM
thestoneman's Avatar
Quoted: 126 Post(s)
Liked: 47
Sounds like you want a gobo projector, but they are not exactly versatile. It basically projects light through a decorated filter...typically showing a logo.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
post #8 of 9 Old 02-11-2014, 08:55 PM
olyteddy's Avatar
Quoted: 523 Post(s)
Liked: 912
No it doesn't. Did you check the link in the first post?
🔥🔥🔥 Sent from my Samsung Note 7 Using Ove Glove™ 🔥🔥🔥
olyteddy is offline
post #9 of 9 Old 02-11-2014, 10:56 PM - Thread Starter
user857's Avatar
Right, the interactive bit (of the link I provided) I can develop myself. I just need something with high enough intensity to show reasonable details on the ground with. Ceiling height is not a limiting factor at this point.
Thanks for all the help so far everyone!
user857 is offline
