Basement Theater/Media room on the CHEAP! - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-15-2014, 07:10 PM - Thread Starter
hifibuyguy's Avatar
Quoted: 22 Post(s)
I think I'm at the point where I can start a thread of my on the cheap man cave. We bought our 1950’s ranch house in November 2013. The interior needed a ton of work. We knocked down three walls in the living room/dining room to open up the kitchen. With that “mostly done” I’ve been given permission to start my “Great escape” theater/media room. A major problem with the room is it’s ceiling height, it’s only 83” high….just under 7’ with a metal beam running right through the middle of the room at 6’ high. The room itself is not really the emphasis, more of the equipment really. I’m not going to be doing a lot of sound deadening….I’m not going to be de-coupling the studs from the walls or anything like that…but it’s going to be fast and cheap…the money is going into the gear.
With this build all 7 speaker are going to be powered. This comes with challenges when wiring…all speaker locations will have a power outlet, a xlr cable and I’ll also run 12/4 speaker cable just incase I switch back to “regular” speakers. Speaker are Emotiva Stealth 8’s for R&L…Stealth 6’s rear for the time being a pair of Adam A3 for sides. I’m waiting for Emotiva to come out with their Stealth 88 for a center.
This will be a semi dedicated theater/game/music room. I have a home built HTPC with a few Terabytes of HD for movies and music. My wife is a big gamer and I’m a big two channel music fan.
Here is a link (hope it works) to what the basement with theater looks like
http://planner.roomsketcher.com/?ctxt=rs_com&language=en#/?pid=1153306
I’ve been working a few hours on weekends and during the week when I get a minute. I’ve got all but one xlr run of the low voltage wire, and I’ve got about 85% of my electrical run. My good friend (an electrician) is coming over tomorrow to help me tie a few things up and give me more direction. I’m at the drywall point right now…but I’m going to have to either enlist my wife or a friend to help.
Projector is an Epson 5030 on a Elite 109" screen, I just set up the projector for the first time a couple days ago and was totally blown away...I can't wait for the room to get finished.
This picture is standing in the back of the room looking toward the front screen wall (wall not built)
Same shot with wall built
You can see the metal beam and the screen temporarily mounted...the LCD tv will be mounted to the "screen wall" and I'll drop the screen in front of it when using the projector. I just received my DVDO Quick6 HDMI switcher that has dual HDMI outputs that mirror each other. I did a dry run of everything today and I'll do another tomorrow just to make sure everything is working before the drywall goes up.
Here is a pic with screen down, Stealth 8 in a corner...
Watched a little Sochi last night..
Another Pic
This was from about where the Right speaker will be looking toward the back, the green chair is about in the middle with the metal beam above it.
Emotiva XMC-1, Tekton Double impact, GoldenEar XXL center, Airmotiv 6's, GoldenEar Aeon 2's rear, Epik/DIY sub, Oppo DVD, Parts Express 15 sub kit, Epson 5030 projector, Crown XLS2500 X 4, 1 running the Tekton's
hifibuyguy is offline
post #2 of 7 Old 02-16-2014, 08:43 AM
DiMora's Avatar
Looking good, Michael!
I forgot I had an account on here.
I can't wait to see and hear it in person!
Shane
"This one goes to 11"
More is better.
DiMora is offline
post #3 of 7 Old 03-07-2014, 06:11 PM - Thread Starter
hifibuyguy's Avatar
Quoted: 22 Post(s)
Just a few update pics...started drywall this week, the winter up in Detroit has been brutal this year, it's been ruff getting motivated. I've got a friend coming over tomorrow (Saturday) to help finish the drywall. I'm hoping to finish mud/sanding this week, then painting and tying in the electric.
A8992ED6-1799-4335-AABC-F351C8BCADAB_zpsezpwuvt1.jpg[/URL
I'm using 1/2 plywood on the screen wall where my 65" LCD will be mounted
post #4 of 7 Old 03-25-2014, 05:57 PM - Thread Starter
hifibuyguy's Avatar
Quoted: 22 Post(s)
I've got a ton of work done, I finished all the electrical switches, mounted the projector and fired up the system for the first time since I put up the walls and painted. I didn't have my center or rear back speakers but it sounded pretty good. The picture from my Epson 5030 is just beyond my exceptions.
Door installed
Front screen wall...screen mounted.
Left front Emotiva Stealth 8
A little ESPN
post #5 of 7 Old 03-27-2014, 02:22 PM - Thread Starter
hifibuyguy's Avatar
Quoted: 22 Post(s)
Got some paint up on the walls today and the projector finalized in place.
post #6 of 7 Old 04-21-2014, 06:56 AM - Thread Starter
hifibuyguy's Avatar
Quoted: 22 Post(s)
Getting close to finishing!! I had to wait to purchase my seating before closing up one of the walls....There was no way the love seats would fit in there if I hadn't. As it is, it's a bit tight but comfortable.
From the screen wall
I just have a couple more pieces of drywall to cut and hang, then it's mud and paint. Hoping to be done later this week.
post #7 of 7 Old 02-28-2016, 11:59 AM
DiMora's Avatar
You need some updated pics with the Triton Ones and the new screen!
More is better.
DiMora is offline
