Archaea's multi-purpose Home Theater room - Page 6 - AVS Forum | Home Theater Discussions And Reviews
 626Likes
Old 06-19-2014, 05:58 AM
hltr's Avatar
Liked: 26
Great work Jonathan
____________________
Brian's Bar Build
hltr is offline
Old 06-19-2014, 06:44 AM
Pain Infliction's Avatar
Quoted: 978 Post(s)
Liked: 506
Question.....How does the carpet impact the sound compare to the tile floors you had at your last house?
The Thompson Theater
RIP William Alexander
Pain Infliction is offline
Old 06-19-2014, 05:16 PM
carp's Avatar
Quoted: 2651 Post(s)
Liked: 1926
I went to Jonathan's last week to check out his room. The amount of changes he has made since the last time I was there are very impressive! The picture quality improvement from the 8350 is obvious even to me, a non videophile.
I also think the baffle wall is a impressive upgrade (although it could be the treatments he has done), I brought over 2 of my surrounds (elemental designs Cinema 6's) and with the speakers in the baffle wall I thought the sound was way better than what I heard in my room when I tried the eD's up front as mains. In fact, I preferred the eD's to the Macke's head to head for 2 channel stereo. The Macke's have a "echo" sound to them, like some kind of receiver dsp setting (concert hall or whatever but not that pronounced, it's very slight). Off axis the Macke's are much better than my eD's however, so as surrounds I think it would be a worthwhile upgrade.
Jonathan has said for a long time that the Macke's sound great with all of them going in all channel stereo. Well, I agree. Jonathan's Onkyo must do all channel stereo different than my avr. With mine, you lose the soundstage it just sounds like all sounds are coming from everywhere and nowhere. At Jonathan's you still have this great up front soundstage, singer in the middle, etc. and just a nice full sound around you without it being obvious that the surrounds are on.
With all the Macke's going I didn't hear the echo sound that I heard in 2 channels that I didn't like.
We watched parts of Gravity in 3D and the effect was awesome - loved it. However, we watched Men in Black 3 and it was just ok, in fact I think I would have preferred the 2D.
I never did get a chance to hear the 228's in the baffle wall, I'm very curious what that sounds like.
The screen is awesome - looks massive but crystal clear at the same time. Is AT all it's cracked up to be? Well, I've now experienced a LOT of AT setups and honestly the only difference to me is when I'm fully reclined in the chair with my feet up. When I'm sitting like this in my room I can tell my center doesn't sound great and sometimes it's harder to understand speech. However, when I'm sitting upright in my room I can't tell the difference between my setup and AT. The problem is I ALWAYS watch movies in the reclined position so......
Bottom line, awesome room man and still getting better!
hltr likes this.
carp is offline
Old 06-19-2014, 06:28 PM
Quoted: 978 Post(s)
Liked: 506
carp.... That is a good thing that you cant tell a difference between AT and non AT. So does this mean that you might get an AT screen now?
Old 06-19-2014, 06:51 PM
stormwind13's Avatar
Quoted: 62 Post(s)
Liked: 96
Onkyo is the only brand other then yamaha where the all channel mode sounds good to me.
stormwind13 is offline
Old 06-19-2014, 08:03 PM
stitch1's Avatar
Quoted: 322 Post(s)
Liked: 264
Have you tried Denon? Theirs sounds the same as Onkyo's to me.
stitch1 is online now
Old 06-20-2014, 05:22 AM
Quoted: 978 Post(s)
Liked: 506
I thought there was a blind avr shootout and people could not tell the difference between different brands?
Old 06-20-2014, 07:03 AM - Thread Starter
Archaea's Avatar
Quoted: 3028 Post(s)
Liked: 2623
If anyone knows of the shootout Pain Infliction is referring to I would like to read it.
KC group did an amp comparison that no one could tell the difference in, but the processor comparison/Audyssey vs. MACC, vs YAPO, vs Trinnov comparison is still a future plan.
Archaea is online now
Old 06-20-2014, 07:09 AM - Thread Starter
Archaea's Avatar
Liked: 2623
Thanks Sheldon.
I agree with everything you said. I think baffle walls/AT screens are perhaps are a minor (but more than slight) improvement. Not sure they are worth tearing apart a room or building in - unless you to do unless you already have an easy way to implement like I did. It's not like I couldn't tolerate a non AT screen now that I have an AT screen. It's nice to have the center dialogue come from directly behind the screen, but the Left/Right to me don't really matter if they are directly behind the screen. AVR processing is so good these days with 5.1 and 7.1 tracks that I think as long as your speaker distances are set correctly - you have some generous flexibility as to the placement of your speakers.
Old 06-20-2014, 07:31 AM
stitch1's Avatar
Quoted: 322 Post(s)
Liked: 264
We are talking about the processing of all channels stereo.Some brands process it differently. I think Archaea's two channel stereo is WAYdifferent than what I am use to hearing. However, when it comes to amps, youare correct; no one could tell a difference.
Old 06-20-2014, 07:51 AM
stitch1's Avatar
Quoted: 322 Post(s)
Liked: 264
Thanks Sheldon.
I would agree with you for the most part. But think of howmuch further out (left and right) your speakers would have to be with thatgiant screen, putting your right speaker much closer to the corner of your room.Also, your center would be much lower than it was in your old house. You dohave a big room that helps a lot for placement. However, think if you wantedthat super wide screen in a much narrower room. I think by going with an ATscreen you added a lot of convenience.
In my mind, for a lot of rooms there are far more pros thanthere are cons for an AT screen. Yourold room would have been a PITA to do an AT screen in though. Some rooms work others don’t.But overall if someone has the option to do an AT screen, then I say, go forit.
Old 06-20-2014, 07:52 AM
Reefdvr27's Avatar
Quoted: 1572 Post(s)
Liked: 1053
Sounds like a good day. I went back and forth on an AT screen and decided for many reasons for myself why I am not doing it, some would not agree, but again they are my reasons. Probably when I build a new home and build a new theater the proper way I will certainly do it, but for now I am happy with my plan for a fixed screen. One weird part of me likes to see my equipment. I would hate to upgrade up to the 215's and never see them?
Reefdvr27 is offline
Old 06-20-2014, 07:57 AM
Quoted: 978 Post(s)
Liked: 506
Ok gotcha.
Old 06-20-2014, 07:58 AM
Quoted: 62 Post(s)
Liked: 96
I have not. I found I did not care for Sherbourn's and a couple other brands. I think pioneer and sony.
Old 06-20-2014, 09:09 AM
carp's Avatar
Liked: 1926
I CAN tell though when I am in my room and I'm fully reclined since some of the sound from the center channel gets blocked. Still, I don't know if it's enough to push me to go AT. There are always trade offs, for one I'm sure I'd lose a lot of brightness from the screen.
carp is offline
Old 06-20-2014, 09:13 AM
carp's Avatar
Liked: 1926
That's how I do it in my room and my screen is even wider, but luckily stereo sounds better to me with the mains really wide. I've tinkered with that sooo many times and I always go back to the wide mains - with the 212's anyway - hopefully it will be the same with the 215's.
carp is offline
Old 06-20-2014, 09:15 AM
carp's Avatar
Liked: 1926
Exactly, I gotta be able to see those behemoths!!
If I ever do go AT I'm willing to bet I'll only have the center channel behind the screen.
carp is offline
Old 07-14-2014, 03:49 PM - Thread Starter
Archaea's Avatar
Liked: 2623
I'll be hosting a movie night this Friday 7/18 at my place for anyone who'd like to come and see my new setup. Panasonic PT-AE8000U, 144" Seymour XD 2.35:1 screen, Mackie C200 surrounds, JTR 228HT L/C/R, JTR Captivator subs, etc.
I'll be showing the movie Collateral (hopefully it's something you guys haven't seen yet)
http://www.rottentomatoes.com/m/collateral/
Or if people attending veto that one for some reason or another - I'll pick another film. I prefer lesser known but great movies (or new movies) to avoid boredom of a full movie rewatch, but will surely show a few well known demo clips for the comparisons - including a brief 3d demo with the movie Gravity for anyone who hasn't seen 3d at home. (anyone have any extra compatible 3d glasses? I currently only have four)
Let me know who is attending so I know how many to plan for. I can PM my address for those who don't know it.
Be there at 7PM - eat dinner before you get there - but I'll have soda/beer/snacks. We'll go as long as people have interest.
Old 07-14-2014, 07:06 PM
Quoted: 62 Post(s)
Liked: 96
Live closer. Kthx.
Old 07-14-2014, 07:26 PM - Thread Starter
Archaea's Avatar
Liked: 2623
hahaha
Old 07-14-2014, 08:26 PM
NWCgrad's Avatar
Quoted: 1260 Post(s)
Liked: 1270
Why dont you bring your room with you to PA? You could put it in my basement in MD.
I should get back to KC in Dec/Jan; would love to see/hear your awesome new space.
______________________________________
Home Theater:
http://www.avsforum.com/forum/15-gen...sement-ht.html
NWCgrad is online now
Old 07-14-2014, 08:42 PM - Thread Starter
Archaea's Avatar
Liked: 2623
I look forward to giving you the demo!
Old 07-15-2014, 01:25 PM
superleo's Avatar
Quoted: 79 Post(s)
Liked: 302
Anyone know an inexpensive teleportation service?
You guys have a great time. I'm sure Archaea will post how the event goes.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
Old 07-15-2014, 02:17 PM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5597 Post(s)
Liked: 4544
Originally Posted by stormwind13 View Post
Live closer. Kthx.
For cereal.
Scott Simonian is online now
Old 07-17-2014, 06:10 AM
Reefdvr27's Avatar
Liked: 1053
I have heard just the center behind the AT screen sounds better. I was talking with someone the other day about it and his comment was it completely disappears. Last night I was looking at options for an AT screen, but I thought maybe just the center channel might be a possibility. I only have about 18" as the window is in the way. I'm going to give it a shot.
I picked up the Prestige that you mentioned way back in this thread and I really liked it. I had never even heard of it until you mentioned it. Speaking of 3D glasses. I have 4 pairs of Samsung glasses for my HDTV. Do you think that they will be compatible for the Panny 8000 ?
Old 07-18-2014, 09:30 PM - Thread Starter
Archaea's Avatar
Liked: 2623
3 nights with guests in a row! That was fun! I think everyone enjoyed themselves. I had three guests tonight - AVSForum Cvinfig and ChldsPlay w/ his G/F. Co-workers the previous two nights.
Good times!
We watched Ender's Game tonight and did some demo clips. I hope they enjoyed the evening and will join the KC group for future movie nights.
Old 07-19-2014, 02:33 AM
coolgeek's Avatar
Quoted: 634 Post(s)
Liked: 286
Good times!
I am so jealous of you guys who have your home theater ready for guests. Mine is always 'coming soon'...
coolgeek is offline
Old 07-19-2014, 07:52 AM
Reefdvr27's Avatar
Liked: 1053
I'm with you brah. I started my theater build and plans in September and it is almost September again. Would have been done a month ago if the guy helping would show up. The guy I hired has been a nightmare. He is doing it on the side, but still, he just finds a million reasons to not come. Great guy and all, but man he just does not want to work. This week has been the most he has worked yet. Hoping to be done by next weekend.
Old 07-19-2014, 12:21 PM
coolgeek's Avatar
Quoted: 634 Post(s)
Liked: 286
Don't get me started on contractors. My house has been in renovation for 2 years now. Electrician, Plumber, etc, always find excuses...
But slowly and steadily, it'll eventually come together.. fingers crossed!!!
coolgeek is offline
Old 07-31-2014, 03:01 PM
TMcG's Avatar
Quoted: 1129 Post(s)
Liked: 962
What a gigantic difference from v.1 to v.2. Excellent work.
Question about the baffle wall treatments....is that OC703 with black facing or something like Insulshield black? And was it available locally or did you have to order it online? Looking for similar for my baffle wall and need to place an order soon.
TMcG is offline
