I want to mount a screen to my Murphy Bed. Can I do a Plasma or Projection Screen? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-07-2014, 12:10 PM - Thread Starter
USSValor's Avatar
I just bought a Murphy (wall) Bed for my small studio (efficiency) in Fort Lauderdale. I am including pictures here:
I am buying the same exact model bed as the one above, but without the lights installed on the bottom of the sofit leg. I am ordering the bed with a sofit leg because it more support (weight) than a pullover leg and I can pull the bed down without handles. As shown in the picture, the sofit leg is mounted on the face of the bed panel. The bed is currently being built and it's set to arrive in 3 weeks. I am about to buy a plasma TV to mount on the face of the bed panel (below the sofit leg) but the salesperson who sold me the bed says he doesn't recommend it.
Is anyone out there as crazy as me and wants to mount (or has mounted) their TV to their Murphy bed? It's an incredibly strong and sturdy piece of furniture (authentic Murphy, not a cheap/generic wall bed) and I think it could support the weight of a 40-pound 50" plasma.
The other option is to install a screen to the bottom of the sofit leg, which means that I'd also have to install a projector somewhere in my already-cramped room. I cannot mount it on the ceiling because there is a fan.
Val Lorien
Blu-ray: Anyone else surprised that Sony finally won a format war?
USSValor is offline
post #2 of 7 Old 04-07-2014, 12:45 PM
Waterboy77's Avatar
Quoted: 562 Post(s)
Liked: 283
Did the salesman say why he didn't recommend it? Maybe it was a weight balance issue
You would have to look very closely at the mount connections as they are designed for downward force.
Or look for one that allows you to quickly remove the TV before lowering the bed.
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #3 of 7 Old 04-07-2014, 02:35 PM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Do a search for Murphy Bed, someone else already did this a couple of years ago..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 7 Old 04-07-2014, 07:15 PM
MrBlond's Avatar
Apparently if you lay a plasma face-down, the glass can break.
MrBlond is offline
post #5 of 7 Old 04-07-2014, 10:19 PM - Thread Starter
USSValor's Avatar
Oh? Even if it doesn't touch anything?
Val Lorien
USSValor is offline
post #6 of 7 Old 04-08-2014, 05:54 AM
airscapes's Avatar
Quoted: 390 Post(s)
Liked: 307
Here is the one I was referring to.
http://www.avsforum.com/t/1346961/wall-bed-tv-mount/0_100
Doug
post #7 of 7 Old 01-27-2017, 04:49 PM
AndyW318's Avatar
I just did this with a 2016 LG B6 OLED. I supported it with vibration damper mounts on the bottom and a grooved board at the top (also supports the Kinect when needed). The room is our TV room 99% of the time, but an occasional guest room. So far, it works great!
-AndyW
AndyW318 is offline
