If you don't have bass shakers-GET THEM!!! - AVS Forum | Home Theater Discussions And Reviews
Closed Thread
post #1 of 43 Old 07-17-2002, 01:44 PM - Thread Starter
WJSD's Avatar
I was watching "The Others" with my wife the other day and i swear she flew 5 feet off the couch on some of the scare you scene's
1.when you hear the footsteps across the floor
2.when the door shut on it's own
There was not a 3 because she left the coach:D
The Technics receiver really did not do the job before but then i bought myself seperate amps , tube for the fronts and a 5 channel B&K for the rest and the technics sh-500 processer to control it-----------WOW!!!!!!!!!!
Wayne
18 PJ purchases from CuRT Palme and still counting.......and it was supposed to be just a hobby!!!!!!!
WJSD is offline
post #2 of 43 Old 07-17-2002, 03:14 PM
Kipp Jones's Avatar
I have wanted to get these for a while but it has been a tough sell to the wife.
Kipp
Are you boozen & cruisin the AVS? Join us here ---> http://www.avsforum.com/avs-vb/showt...8&page=1&pp=60 good times! www.illinoiscarry.org www.nra.org
Kipp Jones is offline
post #3 of 43 Old 07-17-2002, 03:30 PM
where1's Avatar
My wife thought I was nuts when I bought some of these. Now she likes to show them off to anyone who comes over.
Lest we forget 9/11/01
My System
Paul
where1 is offline
post #4 of 43 Old 07-18-2002, 07:11 AM
MrSquid's Avatar
Will these do the same as a real nice sub sitting in a corner next to your seating? I'm going to be ordering the new SVS PC-Plus 20-39 eventually and have thought about shakers too. My Klipsch KSW-150 (or whatever it is) sub does a good job shaking the couches at times, so I'm guessing the 20-39 would be even better... ? Do the shakers really add that much more over a hot sub?
Xbox Live ID: MihmsMe
MrSquid is offline
post #5 of 43 Old 07-18-2002, 07:57 AM
jinhopark's Avatar
How do you guys mount these bass shakers? I have the Berkline's and the Aura Pro Bass shakers with mono amps ready to hook them up with... I've been told to just strap them under the cushion on the Berkline's but the instructions on the bass shakers say to put them on something firm. Not sure where there is room under or on the Berkline's to mount them on? I'm not sure if I want to put them directly on the bottom or back cushion... I guess I wouldn't want any "localized" shaking, or else it might feel like those Shiatsu Massage chairs...
Any suggestions? I do not have a riser, but wish to put a bass shaker on per chair so that I can turn the mono-amp on/off independently as desired.
jinhopark is offline
post #6 of 43 Old 07-18-2002, 08:52 AM
Kipp Jones's Avatar
What is the best price for a decent set? I could use four.
Kipp
post #7 of 43 Old 07-18-2002, 08:56 AM
hob
hob's Avatar
Don't forget to have a box full of cash ready when the *man* drops in to hand you a disturbing the peace fine. I had a great set up wth twin powered 500 watt sub woofers and 16 inch Pioneer woofes and a ribbon tweeter. My last pinch was in 1994 3rd one cost me $125.
I now use the 5 sounds into headhones which paid for itself over and over and over, I use AHD-750 Denons with 30 Ohm low impedance. No more calls from the man and no more having to add to comunity chest.
hob is offline
post #8 of 43 Old 07-18-2002, 08:56 AM
Huckster's Avatar
MrSquid -
I have two SVS 16-46CS subs. They put out serious bass BUT must be turned up past "spouse approved listening levels" or SALL(tm) to shake the main viewing couch.
I have two Aura bass shakers attached to the main viewing couch. They enhance the experience at any volume including SALL(tm).
Huck
Huckster is offline
post #9 of 43 Old 07-18-2002, 11:19 AM
where1's Avatar
I only have one SVS 16-46CS, and the shakers do add to the experience. I have one in each of my recliners (sorry jinhopark, non-berklines) mounted to a 2x6 that is screwed to the chair's frame. When listening at low-levels, the shakers really add to the sound. I want to add some to the seating platform soon, I like to sit there also, but miss the shake.
My System
Paul
where1 is offline
post #10 of 43 Old 07-18-2002, 05:08 PM
Marissadad's Avatar
I love them, they really augment the bass. I attached a pair of Aura's to the bottom of my couch and put a 50 hz inline filter on them. Shake, Rattle & Roll!!
Oh, and if you need to turn down the LFE late at night you can just turn off the sub and still get the effect with the shakers.
You measure your TV in INCHES? How cute! 9.16 Ft Diagonally, Yeah, Baby!
Marissadad is offline
post #11 of 43 Old 07-18-2002, 06:43 PM
Nick_Scott's Avatar
You would definetly have to mount them to something firm. I wouldnt worry about a 'localized' effect- I have a bunch hooked up to my movie-watching chair, and it shakes the crap out of the whole thing!
Maybe you could mount them inside of the frame, or underneath like I did:
http://www.cs.usm.maine.edu/~brassar...ll/shaker2.jpg
nick
Nick_Scott is offline
post #12 of 43 Old 07-19-2002, 12:07 AM - Thread Starter
WJSD's Avatar
I have mine mounted on the front wooden board of my couch because it is very solid. The last thing you want is it rattling. I would use them with a sub, It really adds another dimension. Simply turning up your sub does not give you the same effect. I have 2 aura pro shakers and that is plenty for a couch.
Wayne
WJSD is offline
post #13 of 43 Old 07-19-2002, 08:37 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Gents ,
Where is the current best place to buy Bass Shakers ? I need another pair for a riser I'm building behind the couch and I'm looking for a good deal .:D
Scott...........................
"Home Theatre is a Journey , not a Destination "
Scott_R_K is offline
post #14 of 43 Old 07-20-2002, 12:08 AM - Thread Starter
WJSD's Avatar
There are a pair of aura bass shaker pro's on e-bay right now.
other than that i guess maybe the aura website.
Wayne
WJSD is offline
post #15 of 43 Old 07-20-2002, 12:11 AM - Thread Starter
WJSD's Avatar
www.smarthome.com/8249.html
WJSD is offline
post #16 of 43 Old 07-20-2002, 02:18 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
WJSD . Thanks fellow Canuck !
I'm sure Smarthome did not ship to Canada before but I see they even offer USP delivery now . Have you used them and what were the "final" charges upon delivery ?
Scott..................:)
post #17 of 43 Old 07-20-2002, 04:39 PM - Thread Starter
WJSD's Avatar
;) Scott I don't remember exactly what i paid. I got mine from ebay awhile ago and i think by the time i paid for a money order shipping and dam duty they ended up costing me $150. I would have paid more:D
Wayne
WJSD is offline
post #18 of 43 Old 07-20-2002, 05:52 PM
BrianR's Avatar
Do you have to buy an external amp for bass shakers?
When you bolt them to the bottm of a chair or couch how does that affect the performance of the rattling affect? I mean doesn't it just shake the bottom of the couch under your butt or does it vibrate the whole couch or chair evenly?
BrianR is offline
post #19 of 43 Old 07-21-2002, 08:46 AM
mark haflich's Avatar
Quoted: 1418 Post(s)
Liked: 1010
These babies violate the laws of physics. They shake the living hell out of a chair and occupant weighing from 200 pounds up, But guess what? No seperate amp is needed. No need to power these babies so they can do that work. Just feed them off the line level LFE output of your 80 watt per SS receiver. :)
Yes, you need a powereful external amp. Doesn't have to be expensive though. A couple of hundred watt used Hafler will work fine as well as many others.
mark haflich is offline
post #20 of 43 Old 07-21-2002, 09:03 AM
Scott_R_K's Avatar
Quoted: 30 Post(s)
DJ Amps will work very well as you are not as concerned about true audiophile quality when they are connected to a pair of Bass Shakers as when they are hooked to your finest loudspeakers .
Here is a good selection and the prices are very low...
http://www.123dj.com/a_amplifiers.html
Scott................:D
post #21 of 43 Old 07-21-2002, 01:42 PM
BrianR's Avatar
Originally posted by Scott_R_K
Gents ,
How tall is the riser you are building?
Are you building the riser for additional seating?
As far as Bassshakers are concerned, will old subwoofer amps do the trick?
I have 2 old 100 watt subs sitting in my garage with bad speakers in them. CouldI use them to wire bass shakers too?
BrianR is offline
post #22 of 43 Old 07-22-2002, 05:49 AM
pixie's Avatar
Someone wants to give me two Buttkickers but I don't how to place them. I have 2 rows of 4 chairs each, 1st row on concrete, 2nd on 10" riser. How should they be mounted?
Jim Sentry
pixie is offline
post #23 of 43 Old 07-22-2002, 02:42 PM
Scott_R_K's Avatar
Quoted: 30 Post(s)
Crankit ,
Yes , the riser is for additional seating BUT only as a temporary inclusion . My HT room is not dedicated and hence is required to be a family room now and again . I'm aiming for an 8" platform that I can bring into the room from the basement and then return there once my company leaves .I have individual chairs in the room already and will only have to place them on the riser when company arrives .
The problem so far has been to construct something light and transportable that will "hang" or at least get out of the way while in the basement . I think I've got a working idea but Mom's the word until I can locate the materials .
Thanks for asking ,
Scott..................:D
post #24 of 43 Old 07-23-2002, 06:22 AM
Randy Lorenz's Avatar
I don't believe that bass shackers will be powerfull enough for a riser with two or more viewers seated on it. Although they are considerable more expensive, the buttkicker is the way to go for a platform/riser configuration. My riser has three theater seats quick release bolted to the riser and one buttkicker for the whole thing and it works great. I have attached six rubber pegs to the underside of the platform allowing it to "float" freely over the carpet. You can find the pegs in Granger under isolator mounts. There is a considerable amount of info on buttkickers in the audio forum. Randy
Randy Lorenz is offline
post #25 of 43 Old 07-23-2002, 01:11 PM
imagamejunky's Avatar
Im using 2 buttkickers powered by a Tsunami amp. I built a platform under the seats. Everyone who sits and watches movies loves the buttkickers. They really shake!
My 2 cents.
imagamejunky is offline
post #26 of 43 Old 07-23-2002, 01:45 PM
lsteere's Avatar
Originally posted by Crankit
As far as Bass-shakers are concerned, will old sub-woofer amps do the trick?
Yes! In fact, I actually bought a cheap sub-woofer off UBID for about $50.00. I unhooked the speaker and hooked two bass shakers up in series since they're 4 ohm. Works great, and it has the auto on/off feature that most subs have, plus the variable crossover which is useful for filtering higher frequencies.
BTW: I love Bass Shakers! Adds a lot to the experience.
Larry
lsteere is offline
post #27 of 43 Old 07-23-2002, 02:56 PM
Marissadad's Avatar
Risers are the preferred install method according to the Aura installation guide. I have a pair attached to a 3 person sofa and it can produce much more vibration than is realistic if I crank it up. I leave it set at about 6 (out of a 10) and that is just about right, any higher and I'd probably lose some fillings.
post #28 of 43 Old 07-25-2002, 09:27 AM
BrianR's Avatar
I just ordered 2 sets of bass shakers!
I am going to use old sub amps to power them.
Cant wait to see what it's like to use them.
BrianR is offline
post #29 of 43 Old 07-25-2002, 11:55 PM - Thread Starter
WJSD's Avatar
At first you'll be tempted to crank those things right up, but after falling off the couch 2 or 3 times you will want to back off a little.
The trick is for them to enhance the experience and not to take over.
Wayne
WJSD is offline
post #30 of 43 Old 07-26-2002, 05:36 AM
BrianR's Avatar
Wayne
I agree 100% with you Wayne. I am going to start them somewhere in the middle and back them off just enough to *enhance* my HT and Music. I am extremely picky when it comes to sound. I don't like my subs tuned up too high or low. I don't mess with the treble and bass adjustments ( I leave them at default settings ). I calibrate my setup (both audio and video) so it all intergrates seamlessly.
BrianR is offline
Closed Thread General Home Theater & Media/Game Rooms
