Help running A/V wires through existing walls - AVS Forum | Home Theater Discussions And Reviews
Old 06-17-2014, 11:46 AM - Thread Starter
midwestmuscle's Avatar
I have recently added another tv to my house and instead of paying for another cable box I want to run component cables into basement to other side of room then up to TV, but component cables are very large. Is there a way to splice these or cables that I can add rca jacks. I also want to use a flexible drill bit to install in wall.
midwestmuscle is offline
Old 06-17-2014, 12:12 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
For retrofit you may be better off using a cat5e/cat6 cable and then either an HDBaseT (HDMI-over-category) product or a Component Video-over-cat5 balun. The "better" component video baluns will do analog audio and HD video over a single cable. Two-cable Component solutions are probably cheaper and offer more capability (analog/digital audio, video, IR repeating).
jautor is offline
Old 06-17-2014, 02:08 PM - Thread Starter
Thank you for the help. Can you please help explain what I would need and where would I get the things I need to do this. What is the difference between the 2 and what is the most cost effective.
Old 06-17-2014, 02:18 PM
jautor's Avatar
Liked: 777
Cheapest:
http://www.amazon.com/Tripp-Lite-B13...t+cat5+adapter
(folks have had mixed luck with these, but if they work for you, they work...)
Better (2-cable):
http://www.amazon.com/CE-Labs-Video-..._bxgy_e_text_y
plus
http://www.amazon.com/CE-Labs-Compon...rds=celabs+cat
Best (HDMI using HDBaseT ):
http://www.monoprice.com/Product?c_i...seq=1&format=2
jautor is offline
Old 06-17-2014, 02:27 PM - Thread Starter
Thanks for the help. I didn't know this was even possible.
