Subwoofers - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By Fanman155mph
post #1 of 11 Old 06-22-2014, 07:27 PM - Thread Starter
Liked: 1
Subwoofers
Hello all,
Not sure how to do this so I'll start with what I have.
8 year old DTS Yamaha, Adcom 200watt per channel, MK S100 and I had MK V100s for subs plus rear Bi-POs.
I replaced the MK subs with a Def supercube3 and it quit for the 2nd time. So on the spot I went to Bestbuy, the highend part and bought a close out REL 528se for $2,150 and now I think I could get alot more sub for that kind of money. My question is... What sub would be better with more punch and still have a flat response. I'm using the pre-out LFE to power the sub. Some choices are: keep the sub I have or, the Velodyne Optimum Series 12-Inch, or the Sunfire TSEQ12 True Subwoofer EQ 12 Signature... Any thoughts... I have 5 days left to return the REL 528se ... Thanks for reading....
Fanman155mph is offline
post #2 of 11 Old 06-22-2014, 07:32 PM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4776
Why are you just considering B&M offerings?
ps $2150 for that Rel is a bargain? Saw something you said in the Rel thread but am not familiar with their stuff except that it seems overpriced and has a following of people for the wrong reasons....
lovinthehd is offline
post #3 of 11 Old 06-22-2014, 07:36 PM - Thread Starter
Liked: 1
B&M? Guess I'm out of touch... Sunfire and Velodyne is not B&M I thought... Also I may just keep the REL but I started thinking I may be about alot more bang for the buck..
post #4 of 11 Old 06-22-2014, 07:42 PM - Thread Starter
Liked: 1
What's strange and I never knew.. REL was designed to run with full spectrum speakers from what I have read.... The 528SE I have now sounds great but if you wanted to turn it up beyond normal .. you can't so it seems... like it's set to run the output level 3/4 or more on the LFE input.. seems strange to me.
post #5 of 11 Old 06-22-2014, 09:41 PM
lovinthehd's Avatar
Liked: 4776
B&M = Brick & Mortar. ID = Internet Direct
Better choices IMHO are ID these days altho some of the traditional B&M sub guys are starting to wake up a bit. Then there's DIY and AIY choices which can be a better value depending on your requirements and time available....
post #6 of 11 Old 06-22-2014, 09:59 PM - Thread Starter
Liked: 1
Thank you again for the response/opinion.... I went to a B&M to get it now as my old sub failed without warning... Now I think I payed too much and so forth.. The Sunfire/Carver sub is listed on ebay for $1,425 and includes shipping.. model is TS-EQ12 ... any more thoughts? Thanks..
post #7 of 11 Old 06-22-2014, 10:25 PM
lovinthehd's Avatar
Liked: 4776
Look at Power Sound Audio, SVS Sound, Rythmik, Hsu and Reaction Audio for starters for some ID offerings at various price points and in sealed or ported offerings. What size room are you using? Is it sealed or open to other areas? Are you open to using dual subs?
post #8 of 11 Old 06-23-2014, 06:51 AM - Thread Starter
Liked: 1
room is 14' by 20'
Open doorway to kitchen
Dual subs is cool....
I like sealed subs as I think they sound tighter
What do think of that 12" Sunfire Sub with 2,700watts?
Thanks again..
post #9 of 11 Old 06-23-2014, 12:13 PM
lovinthehd's Avatar
Liked: 4776
room is 14' by 20'
Thanks again..
I don't think much of Sunfire products at all since Bob Carver's departure and my only experience was a friend who had one of the original Sunfire subs but later had amp problems, it did sound nice but I hadn't much experience with subs back then.
There are excellent ported subs as well as sealed, design and execution go further than a general type. The top of the heap of the ID sealed subs IMHO is the Seaton Submersive HP and multiples would be an awesome way to go.
Your space isn't particularly large at 2240 cuft, assuming an 8 ft height, but depends on how large that door opening is and the size of the kitchen as well. Ported designs can often provide higher output and lower extension in larger open spaces than a sealed sub can. An excellent ported design with good output and extension is the Rythmik FV15HP.
I should also mention JTR Speakers subs, the Captivator is very well thought of around here. Also Funk Audio http://funkaudio.ca/ for consideration, some beautiful cabinet options on top of great performance...but will be a bit pricier. There's some great AIY & DIY options too if you want....
You might want to look at some of the testing and information here http://www.data-bass.com/home; Josh Ricci is the main 3rd party tester out there for subs (and a member of these forums and audioholics.com also).
post #10 of 11 Old 06-23-2014, 06:57 PM - Thread Starter
Liked: 1
I wanted to thank you.. I spoke with the owner (Brian, very helpful) of Rythmik and he thought the F15HP sealed sub would be a good setup for me as I also listen to a lot of music and I like the smaller cabinet for the space I have.... I may buy a 2nd sub down the road.... Again thank you for getting me back on track..
lovinthehd likes this.
post #11 of 11 Old 06-24-2014, 08:31 PM
thestoneman's Avatar
Quoted: 126 Post(s)
Liked: 48
If I have $2000 for a sub I am getting a Seaton Submersive.
My Theater Build
Equipment List: Denon X5200, Epson 6030, 120" Carada cinemascope screen, Panamorph U480, Oppo-103, Emotiva XPA-5, SVS PB12-NSD, LSA Statement LCR & surround speakers, Def Tech ProCinema 1000 rears, DefTech DI5.5R Atmos overheads, Grafik Eye 3106
thestoneman is offline
