So, what did you add to your theater this weekend? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 06-22-2014, 06:48 PM - Thread Starter
Rendermandan's Avatar
I'll start off with adding contrast light behind my tv. It really makes the image much easier to see!
I used some left over 5/8" Incandescent rope light that I used for my cove lighting. I then hooked it up to a left over lutron spacer remote dimmer switch I had from a previous project. It ties in nicely with my grafik eye. It will dim up and down with the rest of the lights when I use the ir remote.
So, what did you do?
Rendermandan is offline
post #2 of 6 Old 06-22-2014, 07:09 PM
kenmid's Avatar
Looks great. What type of lights are those?
kenmid is offline
post #3 of 6 Old 06-23-2014, 08:14 PM - Thread Starter
Thanks! Like I mentioned, I used some left over 5/8" incandescent rope light from my cove light.
post #4 of 6 Old 06-23-2014, 08:39 PM
Cksqurd's Avatar
Quoted: 64 Post(s)
Liked: 56
I installed lights under our seats.
Cksqurd is offline
post #5 of 6 Old 06-24-2014, 03:15 PM
Conspiracy*'s Avatar
Quoted: 25 Post(s)
Liked: 38
I went downstairs for the first time in about two months. I carried down the first 8 studs that will eventually become framing for drywall.
"Damn, you can't get black levels like that on your projector!"
- My brother, just before he realized his LED display had died.
Link to my Basement build
http://www.avsforum.com/t/1529034/conspiracy-basement-build
Conspiracy* is offline
post #6 of 6 Old 06-24-2014, 03:40 PM
RTROSE's Avatar
Quoted: 195 Post(s)
Liked: 169
Man that looks fantastic! The only thing I did was add about 4.5 hours on my bulb.
RTROSE
RTROSE is offline
