Mounting 65" TV on a window bar - AVS Forum | Home Theater Discussions And Reviews
post #1 of 12 Old 06-26-2014, 07:32 AM - Thread Starter
nmundy's Avatar
I am looking to mount a 65" LED TV using the middle bar in a window as support. I have looked around an have not been able to find a mount that can be attached to a bar. Anyone has any ideas ? Thanks in advance for any help.
nmundy is offline
post #2 of 12 Old 06-26-2014, 07:55 AM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
Won't that be a terrible place for the TV with all the light around it? If its like the widows I'm used to with wooden frames, the frame is plenty strong to support 50 pounds.
My Home Theater
smarcus3 is offline
post #3 of 12 Old 06-26-2014, 08:09 AM - Thread Starter
nmundy's Avatar
It looks like the window will support the 75 lbs weight of the TV ..i will check with my landlord who would be able to tell for sure. I plan to use a couple of curtains to avoid exposure to sunlight. The question is that i am not able to find TV mounts that can be installed on the middle bar.. any ideas on where to look ?
nmundy is offline
post #4 of 12 Old 06-26-2014, 08:50 AM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
Couldn't you use a normal wall mount plate screwed to a support then to the window.
http://www.crutchfield.com/S-RLH5BGu...l_install.html
My Home Theater
smarcus3 is offline
post #5 of 12 Old 06-26-2014, 09:11 AM
crn3371's Avatar
Quoted: 235 Post(s)
Liked: 191
What's the window frame made of? Mounting to single horizontal strip is going to make for a wobbly mount. If you're going to have curtains surrounding the tv I'd be tempted to attach a couple of 2x4's spanning the window. Then you could attach any type of conventional mount. Would be a lot more secure then mounting to the window frame.
crn3371 is offline
post #6 of 12 Old 06-26-2014, 10:25 AM
NickTheGreat's Avatar
Quoted: 380 Post(s)
Liked: 255
I don't like the idea of mounting to the window bar. Not really sure why.
IF you're dead set on that spot, I'd span some 2x4's across, in front. And put the mount on them.
NickTheGreat is offline
post #7 of 12 Old 06-26-2014, 05:30 PM - Thread Starter
nmundy's Avatar
You mean a wall mount is attached to the wall on one end and the other end(support) attached on the middle bar between two windows ?
nmundy is offline
post #8 of 12 Old 06-26-2014, 05:32 PM - Thread Starter
nmundy's Avatar
That is also a very good idea. I will explore it also if my landlord agrees...
nmundy is offline
post #9 of 12 Old 06-26-2014, 05:33 PM - Thread Starter
nmundy's Avatar
I hear you...thanks for chiming in though..appreciate it
nmundy is offline
post #10 of 12 Old 06-26-2014, 06:16 PM
smarcus3's Avatar
Quoted: 33 Post(s)
Liked: 30
Span the window with 2x4s is what I was driving at as has been suggested already. However, even a large TV is a very static load which a single 2x4 can handle. Therefore it may be okay to just screw into the center support. Not sure how 'beefy' it is.
My Home Theater
smarcus3 is offline
post #11 of 12 Old 06-27-2014, 09:00 AM
Quoted: 380 Post(s)
Liked: 255
Good luck. If he's okay with you lagging in the window, he should be okay with you lagging into the studs.
post #12 of 12 Old 07-01-2014, 10:52 AM - Thread Starter
nmundy's Avatar
Thank you all for the ideas. As suggested, I went with a TV stand as it would have been to much work to mount it on a window & not too safe either.
nmundy is offline
