This can't be the only TV mount on the market? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-03-2014, 11:40 AM - Thread Starter
fastsvo's Avatar
Quoted: 29 Post(s)
Hi Folks,
I am looking for a flat panel mount that is designed to be mounted on a fireplace and it has to be vertically adjustable, where I can pull the TV up and down, so as to be able to change the "installed height" of the unit.
Poking around the internet, I have only found one mount that seems to do what I am looking for but it's rather expensive at $500.
http://www.dynamicmounting.com/
Are there any other competitors? Is there another solution that I need to consider here?
fastsvo is offline
post #2 of 7 Old 07-03-2014, 11:56 AM
xela19115's Avatar
Quoted: 14 Post(s)
Originally Posted by fastsvo View Post
Hi Folks,
Check Monoprice.
xela19115 is offline
post #3 of 7 Old 07-03-2014, 02:24 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
Not really a 26" articulating mount made by Chief that is designed to move every day cost me $350 and is no where near as complicated as that.
Monoprice had one that was the length I needed but reviews said not built to move on a regular basis.. Things that move a lot need to be build with much better materials that things that are static and therefore cost more..
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #4 of 7 Old 07-03-2014, 02:27 PM - Thread Starter
fastsvo's Avatar
Quoted: 29 Post(s)
Which model do you have?
http://www.chiefmfg.com/
fastsvo is offline
post #5 of 7 Old 07-03-2014, 02:36 PM
airscapes's Avatar
Quoted: 354 Post(s)
Liked: 285
Won't work over a fireplace.. looked up the invoice .. was only 25" and I did find it for $318...
http://www.adorama.com/CHMWHUB.html
In use during the day
Against the wall at night set up for the evening
Doug
post #6 of 7 Old 07-03-2014, 03:05 PM - Thread Starter
fastsvo's Avatar
Quoted: 29 Post(s)
Thanks for sharing the pics!
I found another one, but it seems they have temporarily stopped production:
http://mantelmount.com/
fastsvo is offline
post #7 of 7 Old 07-05-2014, 12:53 AM - Thread Starter
fastsvo's Avatar
Quoted: 29 Post(s)
Ttt
fastsvo is offline
