Wiring in Walls - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By flvinny521
post #1 of 14 Old 07-06-2014, 04:59 PM - Thread Starter
Nosferatu's Avatar
Quoted: 143 Post(s)
Liked: 87
Wiring in Walls
I'm in the middle of building my theater room. I have everything bought and I had my first consultation come in to help with the wiring. The guy is telling me it's practically impossible for me to put the wiring in the walls on my setup. The house is already built and the theater room is going into a bonus room on the second floor. It's the ONLY room in the second floor (the stairs take you right into it). It's a cathedral ceiling with no attic access here.
He's telling me it would be cheaper and more economical to just do the raceways to hide the cabling and call it a day.
Is he correct or no? Is there some way of getting the wiring fished through the walls? It's basically a 7.1 setup where the sub sits behind the front right speaker. Everything needs to get fed to the media rack which is in the small closet in the back right corner of the sound stage.
One side coming in would be a coax cable, 3 sets of 12 gauge speaker wire, and an XLR cable for the sub. The other side would have 4 sets of 12 gauge speaker wire coming around to the media rack.
Thoughts? Suggestions? Thanks for your time and help!!!
Thread to Build:Theater Build
Theater: Monitor Audio Platinum PL200/PL350C, Seaton Submerssive, 150" 3D Elite Screens +more
Living Room: Aperion Grand Verus, Outlaw LFM-1 EX, 70" Sharp Aquos +more
Stage 1 - Enthusiasm, Stage 2 - Realism
Stage 3 - Obsession, Stage 4 - Acceptance
...Which stage are you on?
Nosferatu is online now
post #2 of 14 Old 07-06-2014, 05:23 PM
Tom Grooms's Avatar
Quoted: 123 Post(s)
Liked: 205
Hard. To say without seeing it 1st hand but I've never seen a room I couldn't bury wires.
I'd call someone else. If you have drywall or block walls, you can hide the wires. Raceways are for lazy, uninformed or rookie installers. Don't do it!
Hear me now, Listen to me later....
Tom Grooms is offline
post #3 of 14 Old 07-07-2014, 11:12 AM
BasementHT5's Avatar
Quoted: 73 Post(s)
Liked: 42
I agree with Tom here...there's always a way to hide wires. I'm big into having an appearance of no wires, so I'd do everything necessary to take the extra step. This just screams of laziness and I would recommend going with another contractor.
You could remove the baseboards, fish the wires from the attic, etc.
BasementHT5 is offline
post #4 of 14 Old 07-07-2014, 12:00 PM
djearl81's Avatar
Quoted: 12 Post(s)
I also agree. With a little bit of elbow grease you'd be able to hide the wires somehow. It would be cheaper and easier to use raceways, but it wouldn't look as good.
I'm confused too.
djearl81 is offline
post #5 of 14 Old 07-07-2014, 07:48 PM
Scout's staff's Avatar
removing the baseboards and cutting in notches or drilling holes in the framing behind the baseboards. you should be able to run your lines and then fish the lines up the wall to your speaker locations.
hope this helps,
Dan
Scout's staff is offline
post #6 of 14 Old 07-10-2014, 08:52 AM
Bacon13's Avatar
Quoted: 14 Post(s)
Liked: 39
That's what I did. Ran the wires behind the baseboard.
Don't do the racetrack unless you absolutely have to.
Bacon13 is offline
post #7 of 14 Old 07-10-2014, 09:53 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
Drywall is probably one of the cheapest/easiest/most effective thing to change in your house. I'd only use raceways if it were a rental. Your contractor sounds lazy or incompetent.
NickTheGreat is offline
post #8 of 14 Old 07-10-2014, 05:25 PM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
I have had success with pressing speaker wire under baseboards. The carpet generally doesn't go all the way to the wall, so there is space. The carpet will give enough to allow the wire to be pressed in. It is a slow and tedious process, but the wires are hidden. The issue happens when there is a doorway in the path. Then you have to be creative with some sort of channeling under the carpet and a cover on the pad.
jayn_j is offline
post #9 of 14 Old 07-18-2014, 02:14 PM - Thread Starter
Nosferatu's Avatar
Quoted: 143 Post(s)
Liked: 87
well sure the baseboard is simple but what do I do for wall mounted surrounds and the ceiling mounted projector? Do I raceway down the floor from the speaker to the baseboard and then bury?
post #10 of 14 Old 07-20-2014, 10:30 AM
ctviggen's Avatar
Quoted: 115 Post(s)
Liked: 32
The projector could be tough, since it's a cathedral ceiling (in fact, how are you going to mount the projector?). You're going to have to take down some amount of drywall. What's the insulation behind the drywall?
Bob
ctviggen is offline
post #11 of 14 Old 07-20-2014, 11:11 AM
flvinny521's Avatar
Not sure about the projector, but for the surrounds, you could remove the baseboard directly below the speaker, cut a hole in the drywall close to the floor, then another hole in the wall where the speaker will be mounted. Fish the wire straight down, and then out the hole you cut in the wall behind the baseboards and towards the equipment rack/stand. The majority of the wire will be hidden once you replace the baseboards, and it should be easy to fish straight down through the wall since you're not crossing a stud.
jayn_j likes this.
flvinny521 is offline
post #12 of 14 Old 07-22-2014, 06:21 AM - Thread Starter
Nosferatu's Avatar
Quoted: 143 Post(s)
Liked: 87
vinny, thanks for the advise. I do have a new professional installer coming out to take care of this. I'm going to see how it goes. Thanks for the input!!!
post #13 of 14 Old 07-25-2014, 12:58 PM
flvinny521's Avatar
Nice, let us know how it goes and post some pictures. I'm still in the planning and buttering-up-the-wife stages of my own "theater."
post #14 of 14 Old 07-25-2014, 01:26 PM
djearl81's Avatar
Quoted: 12 Post(s)
You can go up the wall from the floor, just cut a little mouse hole behind the baseboard. where you need to go up. To get into the ceiling, you might need to cut an access hole or two where you'll need to change directions.
I'm confused too.
djearl81 is offline
