Advice and or Tips - AVS Forum | Home Theater Discussions And Reviews
Old 07-08-2014, 06:06 PM - Thread Starter
bg182's Avatar
Advice and or Tips
Greetings all. I am going to be building a bar/ Media room when I get back from overseas. I am unable to give specs of the layout at this time. We will be finishing the basement and set up when I return.
I will be using in-wall speakers (monoprice) for our surrounds. Undecided about the sub. Currently looking at the Polk PSW10. The in walls speakers are:
http://www.monoprice.com/Product?c_i...seq=1&format=2 (center)
http://www.monoprice.com/Product?c_i...seq=1&format=2 (Front and sides)
http://www.monoprice.com/Product?c_i...seq=1&format=2 (rears)
TV-Will be the Vizio 70in P series if and when its released. It should be released for a while before I get home so depending on the reviews this could change.
I just purchased a Denon E400 for $279!
All cables will be of course monoprice.
I am also looking at getting the 8 outlet home theater power center from monoprice. This should allow me to plug all my electronics minus the TV into one area?
We chose in-wall speakers due to small kids and not looking to build a mid/high theater room. We are coming from just a cheap vizio sound bar.
I wanted to know what I am to expect using in wall speakers and if anyone has any tips or advice you wish to share.
Once I get return home, I can start to add before and after pictures!
Thanks again
bg182 is offline
