Home Theater concern - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jayn_j
post #1 of 4 Old 07-15-2014, 06:13 PM - Thread Starter
the7thson's Avatar
I am wanting to set up at projector in my living room. I am wanting a 106" screen. My problem is my living room is 13'x19.5' with a 14' ceiling so I need a projector that can reach 19.5' onto a 106" screen. I've been to two stores to research and one says its possible and one says it's not. Need some guidance!!!! Thanks!!!
the7thson is offline
post #2 of 4 Old 07-16-2014, 07:25 AM
NickTheGreat's Avatar
Quoted: 435 Post(s)
Liked: 307
Have you looked at the Projector Calculator?
http://www.projectorcentral.com/proj...ulator-pro.cfm
NickTheGreat is offline
post #3 of 4 Old 07-16-2014, 08:10 AM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Anything is possible if you have the money.
If you can not find a projector that fits you needs with a lense that can be placed in that location (high end projectors have lense options)
You can add an external telephoto lens to reduce the image size.
http://www.navitar.com/pdf/NuViewScr...chure_2013.pdf
Unless you have unlimited funds, everything you do in your HT will have some amount of compromise.. Maybe a free standing cabinet behind your seating but not against the back wall would be a needed compromise if your budget won't allow a high end machine with long throw lense.
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #4 of 4 Old 07-16-2014, 02:13 PM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
I second this. I am running an Epson onto a 120" screen from 19' back and I am nearer the wide side of the zoom. I think I would have no trouble hitting a 106" screen. The projector central calculator seems to back this up.
While there are always tradeoffs among the projectors various features, the Epson with its broad zoom range and 2 axis lens shift always seems to have the edge in placement options.
the7thson likes this.
jayn_j is offline
