Fix BluRay Pillarboxing - AVS Forum | Home Theater Discussions And Reviews
Old 07-16-2014, 08:41 PM - Thread Starter
Liked: 0
Question Fix BluRay Pillarboxing
I have an epson XGA projector (1024x768) and a Panasonic BD10, which is old enough to still send 720p through it's component outputs. XGA projectors naturally have an aspect ratio of 4:3, which is convenient because most of the movies I own on BluRay have 4:3 aspect ratios. However, all 4:3 BluRays are pillarboxed to fit widescreen TVs, and consequently my projector letterboxes the image to make it fullscreen. The resulting image is surrounded black bars. Is anyone aware of a device or trick to fix this? There is a pan-and-scan setting on my BluRay player, but it never works (perhaps Panasonic "fixed" it in one of their infamous firmware updates). I'm also trying to calculate the size of the resolution lost to see if it's even worth buying BluRays anymore.
MaxShreck is offline
Old 07-16-2014, 09:08 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
Did you set the display ratio in the BD player's setup menu to 4:3? You mention a "Pan and Scan" setting, so perhaps this is what you meant.
Also check the ratio setting using the remote - there's probably a toggle between a pillarbox and "full" mode that may help...
jautor is offline
Blu Ray Disc Player , pillarboxing , projector
