Running HDMI in an apartment - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-06-2014, 10:18 AM - Thread Starter
JetSet86's Avatar
Can anyone recommend/point me in the right direction on how to run HDMI cable from one side of the room to another in an apartment? The cable inputs are on the opposite side from where my projector will be mounted. Per the floor plan, the projector will be mounted on the kitchen side of the living room and the screen on the bedroom side. My issue is the long run of cable and not having it sit on top of the carpet.
Name:	Floor plan 2.jpg
JetSet86 is offline
post #2 of 3 Old 08-06-2014, 12:51 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
If you can't open the wall, you don't have much choice.. Throw rugs over cable guards were crossing walking areas.
http://www.cableorganizer.com/cord-c...ity-covers.htm
http://www.cabletiesandmore.com/wall...-protector.php
http://www.cableorganizer.com/articl...ood-floor.html
http://www.doityourself.com/forum/ru...-carpet.html#b
http://www.cableorganizer.com/articl...ire-Cover.html
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #3 of 3 Old 08-07-2014, 08:32 AM
NickTheGreat's Avatar
Quoted: 434 Post(s)
Liked: 307
i'm not usually a wireless video guy, but maybe you would be a good candidate?
NickTheGreat is offline
