Old Samsung plasma generating tremendous amount of heat in bedroom, any solutions? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By jautor
post #1 of 7 Old 08-18-2014, 07:30 PM - Thread Starter
brasskey's Avatar
I have an old Samsung 58" Plasma (Model: FPT5884X/XAA). In our previous home, the TV was located in a large living room. I never experienced any heat issues as the room was probably big enough to dissipate heat better. In our new house, the TV was too large to go inside a recessed area over our living room fireplace, so it is in our master bedroom. It is sitting on a large piece of furniture (drawers) about 5" from the wall. Attached is a rough sketch (not to scale) of the master bedroom layout.
Our room gets unbearably hot when the TV is on for a while. We do have a fan in the bedroom and we have one HVAC unit for the entire house (~2000 sq ft). It's located in the unfinished basement and the thermostat is on the 1st floor. Our master bedroom is on the 2nd floor along with two other bedrooms. The 2nd floor is usually a little warmer than the 1st floor, as one would expect, but not much different. The master bedroom, though, is much hotter than the other 2nd floor bedrooms and hallway. I can only attribute that to the TV as the room feels fine when the TV hasn't been on for a while. You can feel the tremendous heat radiating off the unit when you put your hand by it.
Now to solutions. I know I could install a damper just outside the HVAC unit in the basement on the ductwork that feeds the 2nd floor. But, that would just help even out the slight different in temperature from the 1st floor as it would make most sense to locate a new thermostat in the 2nd floor hallway. Plus, if I did put the thermostat in the master bedroom, the other parts of the second floor would be freezing as it would be taking the temperature of the master bedroom with the additional heat from the TV. Another solution, which seems comical, would be to get a more efficient TV. I know if I got a newer LED LCD, it would probably make a big difference as it would be more energy efficient and put out less heat. But, I don't want to get another TV unless I know it would help.
Anyone experience similar issues? Does anyone have any suggestions for solutions? Thanks.
brasskey is offline
post #2 of 7 Old 08-18-2014, 08:28 PM
mn_hokie's Avatar
Liked: 27
Honestly, I'd say upgrade to a more efficient unit. It's most likely more cost effective than modifying the environment to handle the older one.
mn_hokie is offline
post #3 of 7 Old 08-20-2014, 06:35 AM - Thread Starter
brasskey's Avatar
Thank you for the input.
brasskey is offline
post #4 of 7 Old 08-20-2014, 06:41 AM
Nodscene's Avatar
Quoted: 134 Post(s)
That or get an air conditioner for the room
Make something idiot-proof, and they will build a better idiot
Nodscene is offline
post #5 of 7 Old 08-20-2014, 10:12 AM
airscapes's Avatar
Quoted: 371 Post(s)
Liked: 297
Get an LCD for the summer months and use the plasma in the winter.. Summer winter hook up!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #6 of 7 Old 08-21-2014, 02:22 AM
homerging's Avatar
Quoted: 31 Post(s)
A 58" 1080p plasma from 2007 is going to use lots of electricity. How many watts does it use? It should say on the back. Some of the early 1080p plasmas used over 500 watts so that is like a heater running in your room.
homerging is offline
post #7 of 7 Old 08-21-2014, 08:52 AM
jautor's Avatar
Quoted: 1299 Post(s)
Liked: 832
Naw. Easier to use the LCD year round, and put the plasma on another wall with a mantel surround and the Yule Log BD looping during the winter months! Virtual fireplace with heat!
JohnstownFlood likes this.
jautor is offline
