Optimal stud width for in-wall equipment rack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-22-2014, 01:59 PM - Thread Starter
txjeep's Avatar
Greetings,
I am in the middle of a major house remodel and was planning to install an in-wall equipment rack in my media room. The rack will be accessible from the rear via an air-conditioned closet. My question is about the width between the studs. I have two that are spaced 19" in the exact location I need. That seems a little tight, but my stuff is 17" wide if I recall. However, since I have the wall mostly open, it would be easy enough to move one stud over a little bit, but don't know how far to move it. Suggestions on optimal/reasonable width? Also, is there a relatively inexpensive rack I could buy to avoid building my own? I was thinking 4-6 feet would be more than enough height for the stuff that I have.
Thanks in advance for your input!
txjeep is offline
post #2 of 3 Old 08-22-2014, 02:39 PM
Waterboy77's Avatar
Quoted: 503 Post(s)
Liked: 231
Check out the Show me your RACK thread
Depending on your decision on premade vs. DIY will affect your rough in size
Post #163 is a DIY that YW84U made that I personally plan to "copy"
He goes into detail here DIY A/V rack?
One day I will start the new theater....... one day..... THAT DAY HAS ARRIVED
"If the women don't find you handsome, they should at least find you handy." Red Green
Family Cave Theater
Automation Thoughts/ Questions
Waterboy77 is offline
post #3 of 3 Old 08-26-2014, 12:04 PM - Thread Starter
txjeep's Avatar
Thanks for the reply Waterboy. After reading through the rack thread and doing further research, it looks like Middle Atlantic has a slim5 rack (and a couple of others) that will fit. I may try to make one myself first, but at least I know I have another option.
txjeep is offline
