More than 500 lines from S? - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2000, 04:58 PM - Thread Starter
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
The HBO-HD S output from the DTC-100 looks better than DVD and almost HD quality. Is it possible the S out is sending all the lines of HD?
Bill is online now
Old 03-03-2000, 02:46 AM
baimo's Avatar
No
baimo is offline
Old 03-04-2000, 09:17 PM
Mark Rejhon's Avatar
Liked: 106
No,
However, S-Video has capacity to handle a tiny bit more "TVL" than DVD, if the cable is really good...
1. What you are probably seeing is about 1000x480i worth of resolution for HDTV, compared to about 720x480i for DVD.
2. Also, HD transfers downconverted to 480 scan lines pretty much always look better than transfers done straight from film to 480 scan lines. (Which some DVD's are mastered from)
3. There is more information in HDTV at 19 megabits per second compared to DVD which is at a lower bandwidth. With careful downconversion, you can get better looking color depth - less posterization. And for well-mastered HDTV material, sometimes fewer artifacts (but not always).
Mark Rejhon
www.marky.com
[This message has been edited by Mark Rejhon (edited March 04, 2000).]
Mark Rejhon
www.BlurBusters.com
BlurBusters Blog -- Eliminating Motion Blur by 90%+ on LCD for games and computers
Rooting for upcoming low-persistence rolling-scan OLEDs too!
Mark Rejhon is offline
Old 03-05-2000, 03:24 PM - Thread Starter
Bill's Avatar
Quoted: 69 Post(s)
Liked: 50
Thanks Mark, that confirms what my eyes are seeing-more resolution plus better color with no hanging or crawling dots. I am not seeing any artifacts either. Of course it probably also helps that my set has a line doubler.
Bill is online now
