James' Dugout: Theatre and Parlor - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #31 of 48 Old 02-02-2017, 06:02 AM
Tboy555's Avatar
Quoted: 13 Post(s)
Originally Posted by mastermaybe View Post
The playing surface sits on threaded/adjustable hangar bolts-- I fabricated 4 climate adjusters out of rectangular steel -- many people don't know, but a shuffleboard table is actually supposed to be slightly concave (so the pucks play to the center of the board, a bit), not flat. So three screws (one on the left, center, and right) are set through the aforementioned (4) steel lengths (about 1' from either end and about another 2 1/2 feet towards the center) and into the bottom-side of the board. By adjusting (read:tightening or lossening) a nut on the center bolt, I can draw the table in out or out as needed. About $12 in materials and it worked! This part prolly took the most brain-power, lol.
James
Very neat. I was doing good until this part ^^. Seems a bit challenging!
Tboy555 is offline
post #32 of 48 Old 02-02-2017, 06:14 AM - Thread Starter
mastermaybe's Avatar
Quoted: 435 Post(s)
Liked: 344
Ha ha. Yeah it sounds more convoluted than it really is. I'll take a pic when I get a chance and it will be much easier to understand, I'm sure.
It's a bit of guess and check starting out, as you need to make incremental adjustments and see how the wood reacts. Once it's all dialed in it should stay put, seeing my lower area is climate controlled and I'll eventually seal the underside of the board (to keep moisture from going to and fro).
James
My Parlor and Theatre: "Jimbo's Dugout" : http://www.avsforum.com/forum/15-gen...re-parlor.html
Actual phone call (see pic to left):
 Tech (responding to laughter): "I'm sorry sir, did I miss something?"
Me: "Yeah, a case of Diet Mountain Dew walking across my living room."
mastermaybe is offline
post #33 of 48 Old 02-15-2017, 08:17 AM
GoodAndYou's Avatar
Liked: 0
Jimbo,
Great space! Can you provide some details on your movable riser? Is it on casters? How many and how big are they? Is it set to a pivot point or can you move it wherever?
Thx
GoodAndYou is offline
post #34 of 48 Old 02-15-2017, 02:15 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
Originally Posted by GoodAndYou View Post
Jimbo,
Thx
Thanks sir. The riser is basically a pentagon framed out with 2x10's, 16 on center and covered with OSB. There's a 4" 750lb 360 caster on each meeting point and one in the middle. The whole riser can move as a unit quite easily. I have since built tables and a movable step around it as I don't move it very often and the tables are useful.
Thanks again
James
post #35 of 48 Old 02-15-2017, 03:58 PM
Liked: 1
This room looks great!
My Theater room: 13x10, 92" screen, Epson 3500 projector on shelf, Onkyo Tx-SR504 in 6.1 mode, Klipsch Quintet iii speakers, Dayton 12" sub, Sony Blu-Ray/3D, Xbox 360
Family room: 46" Samsung 3D tv, Pioneer VSX-454 receiver, JBL ES20 speakers, Sony 3D Blu-Ray, Fire TV, Xbox 360, Wii
Future plans: better seating for the theater, possible upgrade to Atmos
NewEdgeMustang is offline
post #36 of 48 Old 02-15-2017, 04:16 PM
Toxic teletubby's Avatar
Quoted: 183 Post(s)
Liked: 304
By thew way...just picked up a new PJ: Sony VPLW45-ES.
I'll post pics unpon install. Very excited!
James
Thoughts on the new Sony?? BTW - Great build. I'm in the planning stage with about the same sq. footage as yours but my ceiling is low.
Marantz SR6010 Onkyo 636 Onkyo NR801
Epson 3700 Sammy 55JS7000 Sammy K8500 Toshiba HD DVD Sony UBP-X800
Fusion 8's -JBL Studio Monitor 4406 - B&W 602's - B&W center BIC F12 Sub
TruAudio Revolve 8" - atmos
Fluance bipoles for rears
Toxic teletubby is offline
post #37 of 48 Old 02-15-2017, 05:51 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
James
Thanks man. The Sony is fantastic- every element of PQ bumped up: color fidelity, contrast, less SDE, black level.
4K needs another 2 steps forward in performance and 2 steps back in price IMO, before I'm jumping.
Good luck on your build- keep that ceiling as high as you can, you won't regret it!
James
post #38 of 48 Old 02-15-2017, 05:52 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
Thanks, appreciate it!
James
post #39 of 48 Old 03-19-2017, 04:23 PM
Quoted: 174 Post(s)
James, if you don't mind me imposing. . .
Where were you able to purchase QSC speakers? Did you get a chance to listen before purchasing? Did you have them shipped or were you lucky enough to have a dealer close to you? There are no dealers near Atlanta on QSC's website, and my google search came up empty for the 1120s and 8200s. Also, what's the ballpark cost of those?
GatorBlues is offline
post #40 of 48 Old 03-20-2017, 01:36 AM
fouraxe's Avatar
Bought my house in December '15 and pretty much had the exposed lower level finished within a month: started Jan 9th, about 95% complete by February 9th (just in time for the Bronco Super Bowl win! ). Took a bit longer for the final 5% and then a bit longer still for the final equipment to arrive.
The home is a new ranch with a pretty decent-sized footprint so I was able to get a shop, art studio, guest/play room, full bath, storage, AND a nice-sized theater area and parlor. Main area is ~ 700 sfq st (~ 18' X 38'). About 1000 squares all day for the "dugout" with bar and landing area.
The idea was a multi-function space with a mid-century industrial motif. I like the idea of a bona fide, dedicated screening room, but it's just too limited for what we like to do, overall.
I am pretty darn happy with it, considering I did 90+% of it myself, all under $8,800 (includes all framing, plumbing, electrical, dry wall, floor and wall coverings, bathroom/bar/bonus room and all permanent fixtures). At 1400 finished sq feet, I'll take it. ~ $6.50 a sq foot!
I left the ceiling exposed in the main area (spraying it FLAT black and hitting every nook and cranny was likely the most BS aspect of the entire project). Still, I'm REALLY happy with the look and the sound once everything was dialed in. Spirited playback can be a bit obtrusive upstairs but I really didn't want to enclose the space- sacrificing the aim of the aesthetic, money, and time to prolly neuter it 6dbs.
I'll add some more images as they come in...
Had to work around some furnishings unfortunately...
Built my own barn doors...bout $45-$50 apiece (+ $60 for hardware)!
Spraying wall...every 6 feet morphs from blue to gray...
Half-ton baffle wall!
Finished barn door (this one leads to the aux room off the lower-level entry) ...
Hang-out near landing area...bar is on casters so it can be easily moved to adjacent outdoor patio area...
Modest 4-5 seat bar. I have a high-top table and the mobile 4 person bar so I didn't really feel compelled to have it take up too much space. Did all of the cabinets and bar myself, stainless tops and plywood cabinets...
Built-in AV cabinet...sound deadened glass door...completely accessible from back-side...again, all done DIY...
Elevated seating area...I made an 11" riser (with step) that will actually ROTATE so both reclining couches face the screen...
Shuffleboard/hangout area...
Couple shots of theater area...all four seats recline as well...
Entrance signage...
UPDATE: 1-12-17 Was never really contented with my "mis-matched" cherry shuffle-board table so I built my own to match the balance of the decor...
James
Hi, where did get your barn door hardware from ?
fouraxe is offline
post #41 of 48 Old 03-20-2017, 08:54 AM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
^ Sorry, but I cannot kill everyone by quoting my original post again.
I ordered the bard door hardware off of Amazon. It's my understanding that about (3) manufacturers make 95% of it.
James
post #42 of 48 Old 03-20-2017, 08:56 AM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
To avoid infringing on forum rules, I PM'd you.
James
post #43 of 48 Old 03-20-2017, 03:38 PM
Quoted: 174 Post(s)
James
Thanks for the PM. I wasn't thinking about pricing being an off limits topic on the board.
How do the surrounds perform? I would be looking at using them for sides, rears, and atmos on the ceiling.
For atmos, was there a reason you preferred to mount them with the tall part of the speaker toward the side wall, rather than putting the tall part of the speaker toward the front of the room for the front atmos row and toward the back row of the theater for the back atmos row?
post #44 of 48 Old 03-28-2017, 01:02 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
Re pricing: they (AVS) generally want it to stick to MSRP, but I don't really even know the bona fide MSRP, so I just thought it'd be easier going PM.
Surrounds are outstanding, thanks. Profiling them the way I did: they work better for ALL of the front seats (radiating from the front seemed to lend too much directivity to just the left or right) and MUCH better for the times where folks are on the back island.
James
post #45 of 48 Old 03-28-2017, 01:04 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
I'll have to add some new pics...I made some updates to the area in the last couple months...
Try to get some added today/tomorrow.
thanks
James
post #46 of 48 Old 07-04-2017, 07:00 PM
Quoted: 25 Post(s)
Liked: 6
James if you don't mind can you PM me the price and dealer you reached out for the QSC equipment. I am based in Michigan and couldn't find one here.
Tarun Koneru is offline
post #47 of 48 Old 09-06-2017, 12:36 PM - Thread Starter
Quoted: 435 Post(s)
Liked: 344
Don't know if you're still looking but check with QSC...there are MANY licensed dealers across the country that will/can sell direct and ship.
James
post #48 of 48 Old 10-02-2017, 08:01 AM
Mike Garrett's Avatar
Quoted: 7085 Post(s)
Liked: 4793
Did that in a month? You must have worked your butt off. Good job.
Now enjoy the space.
Mike Garrett is online now
