new guy building home theater, diy - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-14-2017, 07:37 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Hello wanted to introduce myself and get some feedback.
First off my name is Bryan.
So over the last 1-2 years I've been getting into home theater. I have a room I'm building in my basement that measures about 24'x10 1/2'. I have a false wall for another 18" so total room length is around 25 1/2.
So I started by getting a projector. Went with a Sony vpl hw15. I love it, very quiet and great picture.
The first screen I got was a 125" 2.35:1 from silver ticket screens with a cinema grey screen...FAIL. way to much screen texture...just bad. I also learned audio is important on large screens. So next I did a diy seymour ultra fine AT screen. think it's around 105" and 2.35:1. Waaaay better screen!
I started with cerwin vega ls12s/ls6c with the old screen. WRONG! LOL. After that disaster I bought 2 more ls6c and I ended up 3 cerwin vega ls6c speakers, all vertical positioned for lcr.
Needed a new receiver so I ended up finding an outlaw 1050.
Next it was subwoofer time. I was running a cerwin vega lw 15 for awhile and it wasn't cutting it. Went with a diysoundgroup.com ported cube 15 with dayton sub.
Most recently I needed surround speakers and went with 2 mirage m290s. Since purchasing them I've put them as left and right mains and moved two ls6c to the rear for surround. I've found the less sensitive mirage speakers do not mix well with the vegas. 86db efficiency vs 92, I have read the mirage may be close to 89db but I find that hard to believe. I like the sound from them in stereo or Phantom center mode. The ls6c center is set at -10 and still mics a few db louder with test tones.
I've been using a Sony bluray but recently upgraded to a oppo 83 for better decoding then the outlaw can provide (oppo will be here tomorrow).
Currently all this is set up in a 12x11 room and it gets the job done. Once my room is finished I hope it sounds as good. I'm considering 2 more ls6c to replace the mirage 290s. My only complaint is volume right now since the mirage are so less efficient. I honestly love the sound though and they rock to run as a 2.1 Phantom center setup for tv shows on netflix. I also personally like the ls6c from cerwin vega too. I'm trying to keep cost down because eventually I want diysoundgroup.com home theater monitors or fusion waveguide alchemy 8s to run LCR.
So yea my setup currently is
Sony vpl hw15
Seymour ultra fine AT screen 105" 2.35
Ls6c cerwin vega center
M290 mirage main
Ls6c rear surround
Diysoundgroup.com ported cube 15
Outlaw 1050
Oppo bd83
My only worry is the mirage having such bad sensitivity it's effecting the rest of the settings for the cerwin vega speakers. Maybe the oppo can resolve some of that in its settings.
I've learned a lot, first and foremost, building a screen is the way to go. Secondly is matching speakers for same timbre and sensitivity all around, 3rd I think center channels play a larger role in home theater then left and right mains since most receivers have bass management that makes a 12" 3 way main speaker near useless ( could be wrong on that but I know the outlaw sets mains to small when using LFE).
Anyway just wanted to share my "theater".
trilkb is online now
post #2 of 7 Old 03-20-2017, 10:33 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Well this site blows on an android phone.
Here are some pictures...more to come. The room is much further along then this. But that's an idea. The screen is going on a false wall on the opposite end of the counter
ID:	2038481   Click image for larger version
ID:	2038489   Click image for larger version
ID:	2038497   Click image for larger version
ID:	2038505   Click image for larger version
post #3 of 7 Old 03-20-2017, 10:40 AM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Subwoofer, diysoundgroup.com dayton 15" ported cube.
The cerwin vega ls6c, I have 3 which will probably be my front LCR sound stage, and the two mirage 290s for 5.1 rear surround.
Built a countertop over the weekend out of a 2x8 and 2x4. The cabinet is a 12x24x54 upper cabinet from home depot due to room width. 13$ countertop works for me, and cabinet was discounted to 80-90$. Will be adding moulding for the corner drywall joints.
ID:	2038529   Click image for larger version
ID:	2038537   Click image for larger version
ID:	2038545   Click image for larger version
post #4 of 7 Old 03-20-2017, 03:14 PM
airscapes's Avatar
Quoted: 391 Post(s)
Liked: 307
Well yes it does. Everything blows on a screen smaller than 110" !
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is offline
post #5 of 7 Old 09-20-2017, 12:58 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Well finally made progress, almost done but still more to do.
Going to do curtains or more fleece wrapped 1/4" wood on the side walls. Then some 48/24/1 sound panels. Going to change the lights too so they angle toward the seating position. Built the projector stand out of a free bathroom sink base lol. It's getting there
post #6 of 7 Old 09-20-2017, 01:04 PM - Thread Starter
Quoted: 16 Post(s)
Liked: 1
Still the worst site I've ever used on an android lol.
The attachments are top to bottom, bottom most recent. All black is deceptive, there a good 12-14' from the screen to projector. Screen is a diy job using seymour av center stage uf...106" 2.35:1, speakers are diysg fusion 10 pures, receiver denon x4000, Sony vpl hw 15 for projector.
post #7 of 7 Old 09-21-2017, 11:29 AM
Ladeback's Avatar
Quoted: 559 Post(s)
Liked: 183
Send a message via MSN to Ladeback
If you are using Chrome on you Android phone, click the 3 dots at the top for the menu, then look for Request desktop site. Click the box. The site will then work like it does on your computer. Not sure it will make uploading photos. That has been kind of an issue lately for me. I used to be able to drag and drop and you could see the jpg. Now it just puts a link on there.
You could also download Tap Talk on to your phone or tablet. A lot of people use it and it seems to work better on smaller devices.
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
http://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
