Jlpowell84's HT Room - Page 8 - AVS Forum | Home Theater Discussions And Reviews
 86Likes
post #211 of 240 Old 08-23-2017, 09:27 AM
Bass Enabler
Scott Simonian's Avatar
Quoted: 5972 Post(s)
Liked: 5035
For HT18...
4cuft is the smallest rec.
6-8cuft is better.
More than than does not net much extra performance.
Scott Simonian is offline
post #212 of 240 Old 08-23-2017, 09:43 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
For HT18...
6-8cuft is better.
Those numbers are likely accurate but we're discussing a driver that hasn't been sold in almost (over?) two years. But if you go up to 6-8 cu.ft., you better be at rated power. And in all the systems I ever read about people building, it was always 4 cu.ft. for one and 8 cu.ft. for a dual-opposed pair. Who built an HT18 enclosure at 6-8 cu.ft. for a single driver? I'm sure you'd get a little more low-end extension but you'd have to watch the power so overall output would be a little lower than the standard 4 cu.ft.
David Gage
Deep Sea Sound
"You don't listen to our subs, you EXPERIENCE them!"
dgage is offline
post #213 of 240 Old 08-23-2017, 09:48 AM
Bass Enabler
Liked: 5035
So you're saying 2-3cuft is a good idea then?
I believe I was recommending 4cuft and have built 4cuft for all my HT18's (or 8cuft DO if you want to be technical (no difference)).
Why people chose to build what they did (cram into smallest enclosure possible, plus 4cuft flat pack availability and popularity) is not really the point.
post #214 of 240 Old 08-23-2017, 11:29 AM - Thread Starter
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
Here is 4.01 before the little bit of driver displacement.
Modeled up in Sketchup. Also if moving surrounds forward then I most likely will put smoothing subs in rear corners which will further help with efficiency.
This enclosure is 31.5hx20wx14d (exterior & 0.75 thickness)
@beastaudio , you like that side surround placement better? Call with Shawn is looking like set for Sat...I remember right you were working with Quest?
Name:	Screen Shot 2017-08-23 at 11.23.46 AM.png
ID:	2272030   Click image for larger version
Name:	Screen Shot 2017-08-23 at 11.23.08 AM.png
ID:	2272032   Click image for larger version
Name:	Screen Shot 2017-08-23 at 11.22.53 AM.png
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #215 of 240 Old 08-23-2017, 11:54 AM
beastaudio's Avatar
Quoted: 4148 Post(s)
Liked: 3506
Originally Posted by jlpowell84 View Post
What cu ft would you recommend min for these drivers? I can't say for sure but it does seem that I don't quite get as crazy as some. I will be on two single 15 amp circuits for the room. Plan on putting a Crest on each, prob LCR amps with the Crest running SI's... I can model the enclosures a little bigger but David (Dgage) felt 3 cu ft might be most I should do with the powerful Crest amps and the SI's power handling. But as we know these drivers can handle much more, Nick just keeping numbers conservative
Is 2.3 to 3.0 a vast difference?
For HT18...
6-8cuft is better.
I've had mine in 11 cuft (5.5 net per driver) since I purchased them at the very first shipment of production. They've had up to 1000 per driver at times and have never broken a sweat. This size enclosure yields IIRC right around .707 Q which is a perfect spot. 4 cuft and 1000 watts is fine just as scott said, but I wouldn't go any lower.
Scott Simonian and bscool like this.
beastaudio is offline
post #216 of 240 Old 08-23-2017, 12:19 PM
beastaudio's Avatar
Liked: 3506
Hard to tell but I think you just need to be ever so slightly in front of your ears with the sides and you will be in good shape.
post #217 of 240 Old 08-23-2017, 01:02 PM
Bass Enabler
Liked: 5035
Push them forward a bit so they line up with your knees while sitting.
post #218 of 240 Old 08-23-2017, 01:47 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
And what the heck would you know about setting up a good bass system? Fine, even before you added the near-field HST18s, you had one of the best subwoofer systems I've ever heard. So Jonathan, I think you can stop searching as the man has officially spoken though Scott is also the man and knows more about those drivers than I. I only chimed in because I was concerned about 7-8 cu.ft. being suggested for a single HT-18 which seemed large and dangerous to me, especially with the power you were planning. Now go build them as I'd like to see if we can coordinate your movie viewing with seismic anomalies with the US Geological Survey.
David Gage
Deep Sea Sound
dgage is offline
post #219 of 240 Old 08-23-2017, 11:31 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
Pic below is taken from about knee spot. The fireplace will obviously limit that but it just about lines up with front edge of seating by 4-5 inches. Remembering some Erksine designs I think Shawn might recommend the same as a forward position. I was afraid they were close but I really wanted to get it finalized and emailed off but knowing we would be tweaking it.
Ive never experienced surround forward flanked...
Name:	Screen Shot 2017-08-23 at 11.27.54 PM.png
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #220 of 240 Old 08-24-2017, 08:31 AM
beastaudio's Avatar
Liked: 3506
Your ears have the most trouble with spacial queuing from the rear. If you have a chance to try both positions before buttoning down the final location, I would definitely try that out. You may be very pleasantly surprised at how much more enveloping the SS is with the surrounds slightly forward. It allows your brain to discern between them and rear surrounds MUCH easier.
post #221 of 240 Old 08-24-2017, 10:49 AM
Bass Enabler
Liked: 5035
With the surrounds behind you (all of them) the entire surround field exists behind you. It's not enveloping at all. Wrap around effects are clunky.
I like to sit inside the surround field. It's much more enveloping and connects to the front soundstage much more seamlessly. Also lessens the "need" for wides when there is no "gap" between front and rear soundstages.
Next time you go to a movie theater and sit in your favorite spot, look left and right at the surround arrays. Do they extend forward beyond your seat? They sure do!
post #222 of 240 Old 08-24-2017, 12:04 PM
beastaudio's Avatar
Liked: 3506
It makes you wonder if dolby will actually update the standards for 7.1(+) to reflect this, especially now with OBA. Since I made the move, I have always felt that with the presence of rear channels, the sides definitely require the adjustment just as you stated above, yet they still suggest to have them level or slightly behind on the sides.
post #223 of 240 Old 08-24-2017, 01:29 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
Okay thanks gents. Also something I was perviously thinking about is the side surrounds back where I first had them are DIRECTLY in the path of opposing wall L&R 215's. So those areas will obviously receive some sort of treatment and it's easier to build solid rather than piece around a surround speaker mounted there.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #224 of 240 Old 08-24-2017, 02:03 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
Okay so here I changed all four SI 18's to 4.01 cu ft before driver displacement, moved the second from behind MLP to mid point rear wall. Also moved both surrounds forward.
Question: Running the four SI's off two channels of a PL 7.5 can I use a mini dsp of some sort to individually time align each sub? Or can I only time align the channel? That make sense? Because if I can only time align the channel then I need essentially two equidistant pairs rather than four different locations.
Name:	Screen Shot 2017-08-24 at 1.58.35 PM.png
ID:	2272570   Click image for larger version
Name:	Screen Shot 2017-08-24 at 2.07.06 PM.png
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #225 of 240 Old 08-24-2017, 02:50 PM
carp's Avatar
Quoted: 2880 Post(s)
Liked: 2168
For uploading photos. 'Go Advanced' at bottom of screen, blue button. After that down a little further to left side click 'manage attachments.' Choose your file from hard drive then click upload. At this point it will be a thumbnail. IF you want it to be big like I have been doing then click on the yellow text of the file, it will open a new tab. Copy the URL then delete the tab. Come back to your AVS page and post and click on the little yellow picture with mountain and paste. All done! You prob knew that though...
Thanks! Actually I didn't know that, I have never used anything but photobucket.
I tried it and when I clicked on the upload button I got an error message that said, "Your submission could not be processed because a security token was missing."
carp is offline
post #226 of 240 Old 08-25-2017, 12:17 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Was the window open awhile before you tried to proceed? I think if it sits there for 45 min or so it will time out. Otherwise sometimes I have to take screen shots to reduce file size.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #227 of 240 Old 08-25-2017, 05:45 AM
carp's Avatar
Liked: 2168
Ok thanks man, I'll try the screenshot thing.
carp is offline
post #228 of 240 Old 08-25-2017, 11:42 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
You running Mac? Try a photo here We will get this! LTD02 taught me awhile back. It's easy but if we don't know what all this little damn icons are for it's not lol!
Go Advanced, manage attachments, choose file, upload. If it doesn't upload the page may have timed our or photo size is too big. Then click on yellow lettering and it will open the photo in it's own tab. Copy the URL, delete tab, then click on the little icon that is yellow with a mountain and paste.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #229 of 240 Old 08-27-2017, 12:17 PM
carp's Avatar
Liked: 2168
carp is offline
post #230 of 240 Old 08-27-2017, 12:18 PM
carp's Avatar
Liked: 2168
I think I have it, is it showing up? Thanks man, I appreciate it.
jlpowell84 likes this.
carp is offline
post #231 of 240 Old 09-03-2017, 08:25 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
Yea looks great! Been busy, picked up coaching 7-8th grade flag football so been busy along with picking up intensity of workout focus. Trying to shred up completely before I begin bulking around end of December.
Really loving the chairs, have guests digging the room as is with sheets up for pj screen lol.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #232 of 240 Old 09-05-2017, 06:52 AM
beastaudio's Avatar
Liked: 3506
Cmon man, you need to re-prioritize. We are all waiting....
post #233 of 240 Old 09-05-2017, 10:50 AM
sigma722's Avatar
Quoted: 462 Post(s)
Liked: 249
What site is that calculator from? That would save me a bit of geometry for one of my speaker designs, ha.
sigma722 is offline
post #234 of 240 Old 09-19-2017, 10:38 AM - Thread Starter
jlpowell84's Avatar
Liked: 915
Hey all sorry for delays...got back to working after a few months off after the move. And taking fitness to next level along with coaching 7-8th grade flag football.
What I need to figure out asap is my screen angle. How do I calculate this value?
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #235 of 240 Old 09-19-2017, 10:50 AM
Ladeback's Avatar
Quoted: 555 Post(s)
Liked: 182
Send a message via MSN to Ladeback
Do you mine side to side from your sitting distance?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
http://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is offline
post #236 of 240 Old 09-19-2017, 02:14 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
Do I mind? I'm not sure what it is but Shawn needs my viewing angle statistic and I have never even heard if it before lol.I'm 13.5ft away from an 11.5ft screen. Ive Googled and even asked some peeps and it sounds easy, just have no clue when I don't understand what the stat is for or accomplishes.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #237 of 240 Old 09-19-2017, 04:11 PM
Ladeback's Avatar
Quoted: 555 Post(s)
Liked: 182
Would it be like, what are your viewing angles for your seats? Like this? I am not sure how to calculate them, but if you could draw it at you might be able to figure it out.
http://www.acousticfrontiers.com/2013314viewing-angles/
Ladeback is offline
post #238 of 240 Old 09-19-2017, 09:15 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
double...
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #239 of 240 Old 09-19-2017, 09:30 PM - Thread Starter
jlpowell84's Avatar
Liked: 915
I think this is it.
Does anyone know how viewing angle plays into acoustical planning?
Name:	Screen Shot 2017-09-19 at 9.25.50 PM.png
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #240 of 240 Old 09-27-2017, 12:47 PM
beastaudio's Avatar
Liked: 3506
Shouldn't you be playing destiny 2 right now?
