Mounting the projector - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-19-2017, 02:16 PM - Thread Starter
nwbearcat21's Avatar
My power outlet and hdmi are being centered in the room and 13 feet back from the screen. Looking at how the mounts attach to the ceiling should I have the contractor stick another board between the two studs going horizontal so that I can screw the mount into that? Just need to decide soon before they put dry wall up. Thanks!
nwbearcat21 is online now
post #2 of 4 Old 09-20-2017, 06:47 AM
Spyderturbo007's Avatar
Quoted: 201 Post(s)
Liked: 79
That's exactly what I did so I didn't have to know the exact placement. I used a sheet of OSB, but I was doing double drywall, so it served as the first layer.
If you're just using one layer of drywall, you can put a backer between the joists.
Spyderturbo007 is offline
post #3 of 4 Old 09-20-2017, 12:07 PM - Thread Starter
post #4 of 4 Old 09-21-2017, 11:50 AM
Ladeback's Avatar
Quoted: 551 Post(s)
Liked: 181
Send a message via MSN to Ladeback
From your screen name I take it you are a Northwest Bearcat fan or former player?
Klipsch KPS-400’s FR/FL with built in 15” 300 watt side firing subs, RC-7 Center, RS-3 Surrounds.
Integra DHC-60.5, 5- Marantz MA700 Mono Blocks, Pioneer DV-F727 301 Disk DVD CD Changer, Pioneer DVL-909 Laserdisc/DVD/CD Player, Sony PS3.
http://www.avsforum.com/forum/19-ded...ck-cinema.html
Ladeback is online now
