Room layout advice - maximize seating - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-26-2017, 03:48 PM - Thread Starter
elee532's Avatar
Quoted: 92 Post(s)
Just moved into a new home, and was hoping to setup a projector in the family room. This will be my first projector - replacing a 55" LCD. My hope was to get somewhere between 100" and 120" picture. I'd like at least 6 adults to be able to watch TV/movies. I was thinking of something like an L or U shaped couch. The problem is, as you will see from the attached images, is that there is a support post sitting almost front and center about 128" back from the front wall. I'm assuming if I put the couch in front of the support beam, it will be too close to the screen - especially for folks on the side seats of the U shaped sofa. Of course, putting it behind the support post will look odd.
Wondering if anyone could offer advice on how I might setup this room?
Also notes that usage will be mostly TV viewing (50%) followed by Blu-Ray concerts (25%) and then movies (25%). We anticipate watching with at least some level of lighting on in the room (not theater dark). There will also be a 5.2 audio setup to go along with it.
Thanks for any advice!
ID:	2288718   Click image for larger version
elee532 is offline
post #2 of 4 Old 09-26-2017, 09:44 PM
ChadS13TDI's Avatar
Quoted: 55 Post(s)
You may have to incorporate your seating with the pole. Put the couch just before the pole and build a bar top into the pole and put some seating on the bar top. The pole being close may be a bit of a distraction to those sitting right by it but I don't really see much else.
If this is a space you're really going to use a lot I would definitely reach out to a contractor and structural engineer and see if you can beef up that beam and remove the pole. This is possible it's just a matter of how much $$$. Could be worth it!
Basement Theater/Rec Build 2.0 - http://www.avsforum.com/forum/15-gen...ng-advice.html
ChadS13TDI is offline
post #3 of 4 Old 09-27-2017, 08:17 AM
Ladeback's Avatar
Quoted: 551 Post(s)
Liked: 178
Send a message via MSN to Ladeback
What are the room dimensions? Are you wanting to put the screen on the same wall as the TV? For eye to screen distance for a 120" 16x9 screen could be between 10' to 11'. 11' is what is recommended, but the 2x screen height is used a lot on here. depends on what you are used to. I set at about 11' back from a 120" 16:9 screen, and have sat at 10'. but felt it was to close.
@ChadS13TDI idea of having two rows with one being a bar with bar stools is a good idea. Especially for sporting events. You could put two love seats on both sides of the pole and a bar behind them if there is room enough to fit them in. Average love seat is about 60" wide.
Ladeback is offline
post #4 of 4 Old 09-28-2017, 09:10 PM - Thread Starter
elee532's Avatar
Quoted: 92 Post(s)
The room is about 22' x 18'. There is no longer a TV in the room. The screen would go on the wall where those two recliner chairs are.
I do think I'm going to see what a structural engineer has to say.
Also, notice that ledge/shelf near the top of the wall... that's going to limit by about 12" being able to mount the screen to the top of the 8.5' ceiling. Should I be concerned about this?
elee532 is offline
