RGB switches? - AVS Forum | Home Theater Discussions And Reviews
Old 08-07-2000, 03:09 PM - Thread Starter
DBA_in_MN's Avatar
What are my options for switching RGB signals to my CRT projector?
I would like to switch between my Dish 6000, DVDO, and 1 or 2 computers. The best I can find are the VGA/keyboard/mouse switchers. These would work, but I'm looking for something I can control with a programmable IR remote, or autosensing for a signal.
Let me know your experiences with these? I know some of the computer switches I have used degrade the signal somewhat.
DBA_in_MN is offline
Old 08-07-2000, 04:07 PM
Buddy_Yaussy's Avatar
D,
You could use an Extron unit, such as the SW4ar model. It is on the expensive side, but will not degrade the signal in any way, can be remotely controlled via RS-232, or will auto-switch based the active input.
www.extron.com
Buddy
Buddy Yaussy
My HT Page
Buddy_Yaussy is offline
Old 08-07-2000, 07:54 PM
Jeffrey Macko's Avatar
Anyone have some experience with the belkin Omniview line as far as signal degradation goes?
Rather affordable, with keyboard swtiching by hitting a few keys. (which should be remote controlable with an IR keyboard.
Jeffrey Macko
The Royale Cinema
Jeffrey Macko
RoyaleCinema.com
Jeffrey Macko is offline
Old 08-07-2000, 10:00 PM
Phil Olson's Avatar
What about the Inline stuff. Any thoughts on quality? They seem to be reasonably priced.
Phil
Phil Olson is offline
Old 08-08-2000, 04:54 AM
Tim McCune's Avatar
I use the Extron SW 4AR HV xi (http://www.extron.com/tech/tech.asp?id=np-swxi93) it can be had for around $550. It can switch manually, or when it detects a signal in auto mode. I recommend it.
Tim McCune is offline
