how much 4:3 viewing can be done on a 16:9 set? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 01-26-2000, 10:08 PM - Thread Starter
Nethawk's Avatar
Liked: 118
I am hoping someone will take the time to clarify some issues for me.
I have read that viewing normal 4:3 format on a 16:9 set can have adverse circumstances. Can someone explain this?
I hope to upgrade both TV (TW40X81) and DSS (Dish Network - I currently have just an antenna) at the same time for HDTV programming, but will still be viewing plenty of "legacy" TV & videos, in addition to DVD. Are there STB's that can be purchased to reformat these into 16:9/anamorphic format and eliminate problems and enhance the picture?
I have also read that on these sets with satellite reception sports are often plagued by artifacts. Again, is there a separate device that will eliminate this effect (hopefully the same one as above!!)?
Thanks much.
Nethawk
Nethawk is offline
post #2 of 6 Old 01-27-2000, 01:28 AM
Don Landis's Avatar
Quoted: 1222 Post(s)
Liked: 326
test
My 3D videos and more
Don Landis HT System: Projector Sony VPL VW665ES Players: Samsung UBD K8500 OPPO BD93 Sony BDP S6200 All Regions Player Denon AVR 4311ci, 7.1 JBL Professional series and Klipsch PS3, XBOX360, Dish VIP722K
Don Landis is offline
post #3 of 6 Old 01-27-2000, 12:17 PM - Thread Starter
Nethawk's Avatar
Liked: 118
Thanks, but I was hoping for a little more input!
Nethawk
Nethawk is offline
post #4 of 6 Old 01-27-2000, 07:09 PM
Don H's Avatar
I watch quite a bit of 4:3 NTSC on my Pioneer 510HD and I use the whole screen via Natural Wide mode. That's what I recommend.
That's my story and I'm sticking to it.
Don H is offline
post #5 of 6 Old 01-30-2000, 04:08 AM
Mark Rejhon's Avatar
Liked: 106
Some sets use a combination of stretch and cropping. For example, a 14:9 "zoom" mode which stretches horizontally, but also vertically a tiny bit for about 5% overscan.
The 14:9 aspect ratio has only half the distortion of 4:3 zoomed to 16:9. You do not lose much image! Just an amount of image similiar to overscan, at the top and bottom edges of the screen.
Mark Rejhon
www.marky.com
Mark Rejhon
www.BlurBusters.com
BlurBusters Blog -- Eliminating Motion Blur by 90%+ on LCD for games and computers
Rooting for upcoming low-persistence rolling-scan OLEDs too!
Mark Rejhon is offline
post #6 of 6 Old 02-01-2000, 07:26 AM
Chris White's Avatar
Nethawk: I have the big brother (TW65X81) of the set you are considering. I watch all 4:3 material using Toshiba's TheaterWide 1 mode. This mode fills the screen by stretching the outer edge slightly more than the center which drastically reduces distortion.
Chris White is offline
Closed Thread General Home Theater & Media/Game Rooms
