Framing an angled wall - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 02-21-2006, 12:37 PM - Thread Starter
advertguy2's Avatar
Hello Everyone,
I've got a fe walls that I will be framing soon that are on 45 degree angles and I was wondering what the best way to frame the outside corner of the 45? I wasn't able to find anything with a google search. If someone can make me up a quick diagram it would be much appreciated.
The way I would think its done is to lay out the top and bottom plates for the corner. Then place the studs so that they are touching on the inside of the angled wall, but this would leave the outside of the intersection with a gap that needs to be filled. I made up a very fancy looking sketch in MS Paint and have managed to attach it after having some difficulties (I guess I should read more of the instructions...)
Thanks in advance for any advice.
advertguy2 is offline
post #2 of 17 Old 02-22-2006, 07:56 AM - Thread Starter
advertguy2's Avatar
Hi Everyone,
I updated the original post with a sketch so hopefully that will clear up any confusion as to what I was asking about. Any suggestions?
post #3 of 17 Old 02-22-2006, 01:21 PM
bpape's Avatar
You need to rip a 2x4 to match the angle where they intersect.
I am serious...and don't call me Shirley.
Bryan Pape - Lead Acoustician
GIK Acoustics
bpape is offline
post #4 of 17 Old 02-22-2006, 01:50 PM - Thread Starter
advertguy2's Avatar
I was hoping you wouldn't say that. I don't have a table saw, but I guess I can give it a shot with the circular saw.
post #5 of 17 Old 02-22-2006, 02:28 PM
Bobby_M's Avatar
To be honest, you could probably get away with backing the meeting edges with furring strips to allow you to attach a slightly flattened cornerbead and otherwise letting them hang. It's not that unsupported.
Bobby
Bobby
Bobby_M is offline
post #6 of 17 Old 02-22-2006, 05:57 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
See attached for the method I recommend. Install a 2x4 on the flat at the outside corner.
You don't need complete support at the inside corner. The small gaps actually make it easier to secure the GWB to the studs in the corner.
Mr.Tim is offline
post #7 of 17 Old 02-23-2006, 06:09 AM - Thread Starter
advertguy2's Avatar
Thanks for the ideas guys.
post #8 of 17 Old 02-23-2006, 06:42 AM
BuffBakerGA's Avatar
Just miter the ends of the 2x4 at a 45* angle. Go out buy a miter saw because you will use it forever. To do the job right, you need the right tools...
BuffBakerGA is offline
post #9 of 17 Old 02-23-2006, 07:52 AM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
I actually had a similar issue with my angled bar. The problem is not the top and bottom plates, it's in between where you need something to screw drywall into. I actually cut and secured pieces just for those intermediate pieces. Hard to see them, but take a look at the angled pieces of 2x6s in this picture.
http://public.fotki.com/bketterl/ear.../dcp_1755.html
That gave me a surface for drywall between the top and bottom pieces.
Bud
chinadog is online now
post #10 of 17 Old 02-23-2006, 01:10 PM - Thread Starter
advertguy2's Avatar
BINGO!! I believe we have a winner!!! Way to think outside the box Bud. Thats quite a project you're tackling there. Nice work.
Dan
post #11 of 17 Old 02-23-2006, 01:20 PM
You mean the little blocks? Oh... Well, you still need a miter saw... ;)
post #12 of 17 Old 02-23-2006, 01:50 PM - Thread Starter
advertguy2's Avatar
I've got a mitre saw. Unfortunately it doesn't have an 8' long radial arm on it. Was trying to avoid ripping a 2x4 or 2x2 to fit in the corner with a circular saw. Bud's method is perfect.
post #13 of 17 Old 02-23-2006, 02:16 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
Glad it helped.
I'd also suggest using a heavy joint tape rather than standard stuff (specifically for the corner only), something with rigidity to stand up. I forget the name of the stuff I used, I picked it up from Home Depot and has a like a ruler printed on it. It's thick and requires a few layers of mud to really cover it.
Have fun with the angles. I used two pieces really. I used triangles to secure the two vertical studs together, then used the diamond shaped blocks to have a surface to screw the drywall to. You can probably do it in one step though.
Bud
post #14 of 17 Old 02-23-2006, 02:31 PM
J\V
J\V's Avatar
Don't you want a table saw? :)
My $0.02 in a world where pennies are obsolete...
Sony KDL-60NX810 | Denon 3805 | Polk RTi8+CSi5+PSW505
My HT thread
J\V is offline
post #15 of 17 Old 02-23-2006, 04:54 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 83
Just reread this and I agree with Bobby, you want a metal corner (tape with metal corners are good as well). Mine will actually have some sort of wood front on it eventually, which is why I used the heavy tape.
Bud
post #16 of 17 Old 02-23-2006, 05:15 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
The heavy tape is called StraitFlex.
If it's not going to be concealed with wood I would also recommend the steel reinforced paper tape.
They also make a plastic bead that will conform to most angles.
Tim
Mr.Tim is offline
post #17 of 17 Old 02-24-2006, 05:44 AM - Thread Starter
advertguy2's Avatar
I'll use the steel reinforced paper tape.
I'd love to have a table saw, unfortunately, I live in a townhouse at the moment and space is limited.
Closed Thread General Home Theater & Media/Game Rooms
