Finding pre-wired speaker wire in walls - AVS Forum
post #1 of 4 Old 12-27-2006, 04:23 PM - Thread Starter
Bacchus's Avatar
When my house was built, they pre-wired the walls for 5.1 setup. Unfortunately, the didn't mark where the rear surrounds are. I don't really need the fronts because I"ll run them right from the receiver, but I definitely need the rears. I will probably call them, but I'm afraid the company is going to want to charge me to locate them. Can I find them myself? How? I've gone up in the attic and you can't see where the run down in the wall from there.
Bacchus is offline
post #2 of 4 Old 12-28-2006, 10:28 AM
trekguy's Avatar
Zircon and others make metal finders that can detect copper and other non-magnetics as well as steel in floors and walls. I don't know if they can detect a small copper wire. You might write or call them, http://www.zircon.com
or this-
The fact that an opinion has been widely held is no evidence whatever that it is not utterly absurd.
-Bertrand Russell
trekguy is offline
post #3 of 4 Old 01-10-2007, 08:39 AM
C&K
C&K's Avatar
Call the contractor. They shouldn't have to 'find' them for you, they should have inspection reports showing where the wires are.
C&K is offline
post #4 of 4 Old 01-10-2007, 04:37 PM
bughunter's Avatar
I believe they sell kits for trade contractors that inject a signal on the conductor on one end, and then a handheld signal tracer picks up radiated signal from the wire carrying the injected signal.
I've seen these used but never learned what they're called. Talk to a professional contractor and see if they can offer suggestions.
I imagine the injected signal would be pretty strong, so be sure there are no components on the other end of the wire!
bughunter is offline
User Tag List
